Thanks, Bob-I.
Yes, I'm measuring AC and no there ain't no shorts since I redone and
tested everything prior to the PT. Bad news but that's ok...
I was just trying to be sure before I spend the dough. Thank you!
I guess a BF Bassman PT is in order, right? Any suggestions?
All the best and thank you all so much for your incredible help.
Mains Fuse blowing up
Re: Mains Fuse blowing up
You can use a Bassman PT for a 50 watt Dumble, but a 100 Watt Dumble will need a Twin Reverb PT.
Best of luck.
Best of luck.
