Bluesmaster voltages
Precision PS
117v AC at the wall.
B+1 on Standby 442
B+1 431
B+2 429
6k8
b+3 371
15K
B+4 292
2K2
B+5 283
V1 1 177
V1 3 1.6
V1 6 172
V1 8 1.6
V2 1 183
V2 3 1.6
V2 6 178
V2 8 1.7
V3 1 223
V3 2 26
V3 3 39
V3 6 227
V3 7 25
V3 8 39
V4 3 430
V4 4 439
V4 5 48
What can I do to bring up v1,v2 and v3?
						Low voltages on my Bluesmaster.
				Bob Reinhardt
Re: Low voltages on my Bluesmaster.
you can change the dropping resistors between each node , but with your wall only being 117, the voltages will be a tad low compared to the wall being 120, which is generally where voltage readings are for comparison.
Absolutely change the first dropping resistor to between 2.2K and 3K to taste.
				tubedogsmith
Try some different preamp tubes first before you fire up the iron.  You can get some pretty big voltage swings between different preamp tubes.
Well, I changed out the preamp tubes and I got an appreciable rise in voltage across all three tubes.
With 118 volts ac at the wall I'm now getting what I should at v1 and v2.
v1 1 189
v1 6 187
v2 1 198
v2 6 202
v3 still seems a little low although it did come up by over 20 volts to
v3 1 245
v3 6 247
v1 1 189
v1 6 187
v2 1 198
v2 6 202
v3 1 245
v3 6 247
Looks Pretty Good
For a BM, V3 looks fine.
