TW with 36W OT?
jaysg
TW with 36W OT?
Post by jaysg »
Anybody build an Express, Liverpool, or Rocket with the Heyboer 36Watt OT (HTS-7013-1)? If so, which model, and how did it come out? (it's a 4K primary, fwiw)
dartanion
Re: TW with 36W OT?
Post by dartanion »
I think Billy Yates has done this James. I am not sure what transformers though.
JamesHealey
Re: TW with 36W OT?
Post by JamesHealey »
surely would be just more vox like. and less definition. the wreck rocket has more definition i believe compared to ac30. could be complete nonsense thought as i've just had half a bottle of whiskey lol
dartanion
Re: TW with 36W OT?
Post by dartanion »
Different lam stack, different steel, different impedance, etc. It will sound more Marshallesque than Vox like. There will be less dampening since the reflected impedance is closer to the load, as well this gives you more output. I'm sure it will sound fine as I have done this in an 18watt vein.
breakfastbuddy
your Heyboer 36Watt OT
Post by breakfastbuddy »
will sound good id you missmatch it . do that and raise the impedance to 8k
a smal OT will sound good in a trainwreak ,
Re: TW with 36W OT?
Are you wanting to use a quad of EL84 tubes with this Heyboer OT?
The reason I ask is I have a schematic for a 36w Plexi using that transformer.
Richie
Re: TW with 36W OT?
Post by Richie »
that was for a 36 watt marshall 18 amp. Amp had an 18 watt channel and a TMB channel. I asked Phil at heyboer about an OT that was similar to the 18 watter, only bigger and for 4 EL84s instead of 2. And this is the OT he suggested. I also used the Heyboer standup AC 30 version transformers,and liked that OT a bit better.
