New 80 Watt Wreck done!
Re: New 80 Watt Wreck done!
20X9X2.5" is the size. I countersunk the holes on the deck and behind the rearplate.
						Wrong Layout
Sorry guys. I can't explain what happened. I'll post the correct file tonight when I get home.
Steve
						Steve
Correct Layout
I posted the correct layout file. Now Rev 2-12-09.
one last thing. The NFB comes off of the 4 ohm tap. Other than that it looks right.  Nice job!
Allyn,
Is the PT voltage 400-0-400 with OT of 2000 ohms primary to get that 80 watt rating?
300-0-300V on the PT with 3.3K primaries on the OT Beefed up of course. I never measured the output. I guessed about 80W since this was a rush job and I had to make the faceplates before the amp was built!
So around 514 plate voltage to use 3.3k and equal 80 watts RMS.  Am I calculating this correctly?  514.514/80w = 3.3k
A twin reverb has 450.450/100w =2025 ohm plate to plate and uses a 2000 ohm transformer.
I just got to hear this amp over the weekend -- it rocks!!! All of the good wreck-y things plus more umph, better low end, very cool!
--mark
						--mark
Looks awesome.
Are there any sound clips?
Many thanks.
Many thanks.
Allyn, you should sell this as a kit
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
I second that motion with a big aye.
Allyn and Steve,
I was revisiting the layout and Allyn you said the NFB comes off the 4 ohm tap but Steve has it coming off the 16 ohm tap on the layout. Not sure if Steve wanted to change that. I will make a note on my layout, thanks guys.
- Ron Worley
OK, I'll ask a stupid question here.... Why not use the standard Express PS board and stack 'o caps?  Certainly the output tube sockets could be moved somewhat further left if there's a conflict.....
Just wondering..... maybe I didn't use my brain and missed something.....
Ron
I think the amp looks like half asteroid and half TW.  I'm not saying circuit wise as a asteroid only the way the cap board is built, locking bias pot and power board.  I think it makes for a more stable and stronger amp when hauling around for gigging.
Just my 2 cents worth.
I was wondering about an 80 watt Rocket build as I like the tone stack of the Rocket but need more power baby. If I could just talk the band into miking everything all my problems would be solved with no need for louder.
Updated layout.
Updated the layout on page 4 to correct the NFB to come from the 4 ohm tap. Actually I did this a while back and forgot to post it.
I believe the layout now contains all the corrections posted to date.
Steve
Steve
