I am short one 0.1µF orange drop so had to draw it in on the photo
It was a fun project and easy with PCB construction.
Is that something you would do on an amp that you build for someone else? I've an amp (Mission 5F4 Super) with that feature too but I'm concerned with what might happen if someone were to flip the switch without rebiasing. Would you consider that a potential (no pun intended) issue?Colossal wrote:I also added switches on the back to select the secondary voltage...
Probably not something I'd add to an amp for sale. Purely for my own edification, just to see what I like. Nothing like hearing the differences first hand and it affords some future optionality. I built this to test out the viability of the Express board for RJ and to have something fun to try out ideas on.Zippy wrote:Is that something you would do on an amp that you build for someone else? I've an amp (Mission 5F4 Super) with that feature too but I'm concerned with what might happen if someone were to flip the switch without rebiasing. Would you consider that a potential (no pun intended) issue?Colossal wrote:I also added switches on the back to select the secondary voltage...
Thanks. That's an excellent looking build. I like your menu of features.Colossal wrote:Probably not something I'd add to an amp for sale. Purely for my own edification, just to see what I like. Nothing like hearing the differences first hand and it affords some future optionality. I built this to test out the viability of the Express board for RJ and to have something fun to try out ideas on.Zippy wrote:Is that something you would do on an amp that you build for someone else? I've an amp (Mission 5F4 Super) with that feature too but I'm concerned with what might happen if someone were to flip the switch without rebiasing. Would you consider that a potential (no pun intended) issue?Colossal wrote:I also added switches on the back to select the secondary voltage...
Hey Martin,martin manning wrote:That is very impressive indeed, Dave! A Swiss Army knife amp if there ever was one. I'll be very interested to hear how the PPIMV, the presonance, and the cut control play together.
Thanks Zippy. Yeah, I had some unanswered questions so thought a couple of extras would be cool to try.Zippy wrote:Thanks. That's an excellent looking build. I like your menu of features.
I'm really looking forward to powering up! I think the inclusion of pads for series trimmers in a few key places would be a good addition to a production PCB.fishy wrote:Dave....That build looks cool......
I will be really interested to hear how this one sounds with a 7 string....
All these mods have me thinking back to RJ playing around with a few trimmers when working on the octal based Rocket. I was wondering if it would be worthy of including some provision for these in a later rev board since it did help dial that amp in. I also seem to recall several builders have found more favor with the Liverpool PI in their Express builds than with the Express PI.
Trimmers around the PI would provide the ability to do this.
Of course notI have that 1k/39k mod on my list of things to try, depending how I like the Expresses voice. Have you tried it with your amps Pete?
Pretty sure it was Jackie Treehorn that mentioned it. Good place for a trimmer!fishy wrote:I do recall some posts where someone prefered the Liverpool PI settings over the Express values. Can't find that now though..
Seems to be an area worth explorin. It might also prove useful if you wanted to run different tubes - 6v6s come to mind.
Thanks dude!rooster wrote:Wow, Colossal, that is a very nice build, indeed!
One thing I see in your pic? The ground trace in the preamp area, does the circuit board screw by the input jack have a ground connection to the trace? It looks like it does. Just curious.
