Speaker ID
Markusv
Speaker ID
Hi folks
I hope someone may be able to help
I have an old Alnico 10 inch speaker from a Hammond chord organ
The identification numbers stamped on the basket are as follows:
AO 26689 2SH 3
P10R- C5942-2
220751
Anyone know what this is? (Probably Jensesn?)
Also, the wattage please
Thanks,
Markus V
AO 26689 2SH 3
P10R- C5942-2
220751
Thanks,
Markus V
.........Now where did I put it?
Re: Speaker ID
Markusv
Re: Speaker ID
Thanks!
Physically, it looks like the jenssen, but has a silver frame with no real branding
Markus V
Markus V
Re: Speaker ID
They were probably made specifically for Hammond organs.
Re: Speaker ID
"220751" is the production code:
"220" is Jensen
"7" is the year....I'd guess 1957
"51" is the week....Christmas 1957
Nice find if it works...
Hope this helps.
D
"220" is Jensen
Hope this helps.
D
There are no stupid questions, just stupid people.......
Markusv
Re: Speaker ID
Thanks D
Do you know ( or can you take a guess at) wattage?
The new Jensens are rated at 25 watt
BTW it works beautifully
I have used it in a 6 watt single ended amp and the touch response and balance is great. It has a very mellow break-up too. Suppose that's what you get with a 40+ year old speaker
Markus V
Markus V
Re: Speaker ID
R is 25W, Q is [35]W. There should be a sticker which reads Jensen Loudspeaker Special Design with both watt and ohm ratings.
"A man with an experience is never at the mercy of a man with an argument." Hilmar von Campe
Markusv
Re: Speaker ID
Thanks Kregg
I thought I heard 25 watts somewhere before
No sticker though and I do not belive it ever had one. Came totally naked out of the organ.
The more I compare the basket and the grooves on the cone to pictures of the current Jensens, the more I'm convinced though.....
Markus V
Markus V
Re: Speaker ID
The reissues may be 25w, but the originals are more like 12-15w. Anyway, they are very sought after because the P10R is the classic tweed Bassman speaker.
Markusv
Re: Speaker ID
Thanks!
So I was considering it for a 2x10 Rocket with KT66's (paired with a higher power ceramic)
Now, (at only 15 watt) I think it may get damaged, as the KT66's put out a healthy amount of power
Opinions?
Markus V
Opinions?
Markus V
