Dumble Land/300SL Schematic Starting Here
Well, this is pretty sparse. I wonder if there is enough collective knowledge here to put this together.
Here is a start...
Here is a start...
Re: Dumble Land/300SL Schematic Starting Here
For convenience, here is the link to the longest thread on the topic.
https://tubeamparchive.com/viewtopic.php?t=412&start=0
Re: Dumble Land/300SL Schematic Here
Hi ic-racer,ic-racer wrote:Well, this is pretty sparse. I wonder if there is enough collective knowledge here to put this together.
Here is a start...
none of the DL 300SL I met did have an overdrive. All of them had a reverb. All of them the step filters. So I don't understand in what way this shematic could be a better start for one of a Dumbleland 300SL then a blank sheet of paper would have been? Or didn't I got your point?
Max
The 300sl amps also use 6550 and cathode drivers....
You can get the full power amp directly from an svt.
The filters too are more or less expressed in rdh4.
Good luck.
Good luck.
So far I have come up with the following additions/deletions:
Needs reverb Send and Return pots.
Needs PI balance pot (on back panel).
Needs only 2 bias test points (K1, K2)
Needs 2 Bias pots (back panel)
Needs 3 prong XLR connector not 5
Needs 3 fuses
Footswitch would be for reverb (PAB also???) and no OD circuit
No manual PAB switch (perhaps 3-position J/R switch)
No AC 'convenience' jack
Can't tell for sure these points:
Number of positions for the filters (4 or 6) and location in circuit.
Anything about the reverb circuit at this point.
Needs 3 fuses
Here is the SVT schematic for reference. Do you know if the 300SL uses an OT from the SVT?ampdork wrote:The 300sl amps also use 6550 and cathode drivers....
Good luck.
In the Dumble Land thread first post a reverb schematic is mentioned, but I'm not sure if this is the one:
https://tubeamparchive.com/files/1200dp ... ut_271.pdf
or this one:
https://tubeamparchive.com/files/odreverb_902.pdf
or this one:
I'm going by this "Dumble Land Datasheet" and putting it up for review, in case anyone finds errors in it:
"DUMBLE LAND 300SL"
SPECIFICATIONS
Power Output: 300 watts true power
Output Impedance: 2 or 4 ohms
Input Impedance: NOR = 1M ohm, and FET = 3.3M ohms
TUBE COMPLIMENT
2 x 7025 high-mu twin triodes
1 x 5751 high-mu twin triodes
1 X 12AU7
2 x 12BH7
6 x 6550A beam power
CONTROLS AND EQ SWITCHES
Preamp Controls: volume, treble, middle, and bass
Preamp Switches: bright, deep, rock/jazz, and preamp boost
Filter: Hi and Low step filter
Reverb Contoler: Send, and return levels
Master Section: master volume, and presence
SIGNAL CONNECTIONS
Inputs: NOR, and FET
Access Ports: preamp out, and power amp input (2.5V, 500k ohms)
Outputs: main speaker, and extension speaker
POWER SWITCHES
A.C. mains on/off
A.C. mains grounding
operate/standby
ADJUSTMENTS
BIAS ADJUST
REMOTE SWITCHING
Reverb on/off
Hi Max,Max wrote:... a blank sheet of paper...
Max
I'm sorry if my thread title comes off like John Lennon's posters:
Anyway, as any of the schematics I have done, it starts with the same Dumble template I have drawn up, so it is indeed not far from a blank sheet.WAR IS OVER
if you want it...
This is, of course, a 'group project' your comments will be appreciated if you care to join in
For those not up to speed on intelligent collective decision making systems, I will point out that I am a proponent of #3 in the following essay:
http://public.lanl.gov/jhw/Publications ... Book-1.pdf
Let's see if I am correct
3. The collective is smarter than sum of the individuals in the
collective
Why do you think so? The SVT poweramp shows a 12DW7 / 12BH7 configuration.
The 300SL datasheet on Bill's site and the pictures on Bill's site show a 12AU7 and 2 x 12BH7 configuration.
So please explain, why you write: "directly from an svt"?
Cheers
Max
From what source did you get this info? Could you inspect a 300SL? If yes, do you remember the series #?
Thanks and have a nice weekend
Max
Hi ic-racer,ic-racer wrote:I'm going by this "Dumble Land Datasheet" and putting it up for review, in case anyone finds errors in it:
"DUMBLE LAND 300SL"
SPECIFICATIONS
TUBE COMPLIMENT
1 X 12AU7
2 x 12BH7
SIGNAL CONNECTIONS
POWER SWITCHES
A.C. mains on/off
operate/standby
ADJUSTMENTS
BIAS ADJUST
REMOTE SWITCHING
Reverb on/off
not wrong as far as I know, but there are different ones (Take a look at Bills site). With footswitch for PB and without. With FET and without, with plate reverb, with spring reverb.
Believe me or not: There is not such a thing as a "shematic of a 300SL"! It is the same as with the ODS (and there is no "shematic of a Dumble ODS" too!). Every Dumbleland 300SL has been made for a special client with special features and a special sound (same with ODS). So one allways should keep in mind, that it is not possible to clone "a Dumble ODS". If you degoop an ODS you can at best clone this series # 124 (e. g.) not more not less.
And this is the same with the DL and SSS. If you succeed in cloning the SSS of David Lindley or one of those of SRV, what you get is not "a SSS clone" but in the best case a fine clone of this one specimen.
A lot of the confusion concerning of the ODS shematics and the discussions about the "right one" you find in www is due to the fact, that they are all different. A tech I know has been into many ODS and some SSSs and Dumblelands, and he told me that the differences between different specimens of DL and SSSs are even greater as between two HRM ODS.
So before starting a DL300SL cloning project, it would perhaps be a good idea to make a decision which one you would like to clone. Otherwise chances are great that you end up with the same confusion as with the ODS shematics.
Cheers
Max
Look at the rear of the 300sl. The balance control from the svt is there. ;O)Hi ampdork,
Modding to work with other tubes would not be hard at all. The 12dw7 is like a 12ax7 and 12au7 in one tube IIRC. So pinwise they plop in just fine and in some of the ampegs they recommend doing just that.
In the SVT...a two resistor swap iirc for 12ax7.
So I guess my statement may have been off by one triode, since half of the 12dw7 is most like a 12au7. ;O)
Agreed top to bottom, there is no static state to any of those designs. Emergent and evolving to this very day.Believe me or not: There is not such a thing as a "shematic of a 300SL"!
