Here are a couple of express clips.  This is my 5th express build and this one uses the Toneslut trannies.  I don't think I'll use anything else for my Express amps.
The first one is a stock Express-type, Francesca circuit.
http://www.youtube.com/watch?v=TN0JWiNIk-E
The second is a clip with a modification to the amp - I added a switch to the amp which bypasses the third stage and adds a 330k resistor across the treble pot.  It takes on a JTM45-type quality (though it's better than any JTM45 I've heard).  The mod switch I think is a very good idea, it's quite simple and doesn't screw up the original express.  It's quite a different amp with the switch in the mod position.
http://www.youtube.com/watch?v=vnJg8_5Rssc
The clips are played through my custom vented 1x12 cab I am trying to bring to market through Stone Age Custom Cabs (it's BIG, and capable of more output than a 4x12)
						Express youtube clips
				ontariomaximus
				briango2000
Re: Express youtube clips
That sounds really cool.  Would you be willing to post a little layout on how you did it.  It sounds like it would be a neat simple mod to try out.
				ontariomaximus
This is a true point to point wreck.   NO problems with noise or oscillations.  I can try and take some more photos though.
