reducing bass
				iknowjohnny
reducing bass
Are there any common ways to reduce low end besides adding high end? Adding highs never works well when i try to do this. So i'm wondering if there are any ways, maybe somewhat uncommon that will allow me to reduce lows. the amp has a ton of lows and when i turn the bass pot down it doesn't lose enough till a certain point at which there then seems to get sorta thin. hard to explain, and maybe it's more of a frequency center issue than how much low end there is. I have tried playing with the tone stack caps and bass pot values but that doesn't cut it. It's not a big problem, but it's maybe the only one thats keeping the amp from being nearly perfect to my ear.
						Re: reducing bass
Kevin O'Connor has written a number of books that you might find helpful.
Try these two:
http://www.londonpower.com/catalog/prod ... ducts_id=3
http://www.londonpower.com/catalog/prod ... ducts_id=9
						Try these two:
Re: reducing bass
Use thinner gauge wire, bass frequencies are bigger and have a harder time bouncing through a skinny wire.
Re: reducing bass
Reduce the value of a cathode bypass cap or a coupling cap.  If you have a ~25u bypass cap, try 1u.  If you have a 0.1 coupler, try 0.01.
Then adjust as needed.
				iknowjohnny
Re: reducing bass
Wow, i never thought of that ! I am assuming you aren't joking, but the reason it strikes a chord with me is that i used huge wire in this amp ! 16 gauge to be exact. And the amp has always had a overabundance of low end. And it's not coupling or bypass caps....i have tried every combo imaginable. Nor is it in the tone stack. in fact few would believe me if i told them how much i have tried. And nothing changes it. Well, except one thing...i set the amp back to cathode bias as it was a first, and the change was fantastic. The lows are still there but they are no longer causing the tone to lose definition as it was till then. They aren't 100% perfect to my ear but close enough.Jana wrote:Use thinner gauge wire, bass frequencies are bigger and have a harder time bouncing through a skinny wire.
But thanks for that thought Jana...i may well try rewiring the front end of the amp at least with maybe 20 gauge. It sounds great now, but i think it would sound even better if the low end was more "right". I used 16 because this surplus place nearby had some real nice quality 16 gauge teflon dirt cheap. (i think i paid like $6 for around 100 ft)
Re: reducing bass
uh... he's joking dude.
						Re: reducing bass
Yes, he was joking about the wire....
Would you mind posting a schematic? It would make offering advice easier.
Also, what sort of speaker cabinet are you using?
Re: reducing bass
If it's not the bypass or coupling caps, try lower the bass side of your pickups.
				iknowjohnny
Re: reducing bass
Well, like i said it's no longer really an issue. It could be a little tighter is all, but it no longer muddies up the tone. I'd offer a schematic anyways but the last version of it i drew up was many tweaks ago and i decided not to keep updating it till i come to what i am sure is the final circuit. I may be about there now tho because i haven't yet been this happy with it. But then,.......well, you know how it goes !  The funny thing is, i'm worried that i will NEVER be able to throw it back in the cabinet for good. I'm too much of a perfectionist. yet at this point i could do that and have the best sounding/feeling marshall i've ever owned. It's crazy man...
 The funny thing is, i'm worried that i will NEVER be able to throw it back in the cabinet for good. I'm too much of a perfectionist. yet at this point i could do that and have the best sounding/feeling marshall i've ever owned. It's crazy man...Re: reducing bass
Jana <= she
sorry for pulling your leg last night johnny, I was in a weird mood.
btw, you will never be done with it. There will always be something to improve, lol.
Re: reducing bass
Red wires have always seemed to cut bass for me. The blue wires accentuate bass.Jana wrote:Use thinner gauge wire, bass frequencies are bigger and have a harder time bouncing through a skinny wire.
Teflon only, right?
Srsly...thicker wire can pass amperage more easily...so at least it wouldn't "cut" bass.
Re: reducing bass
yes, teflon wires for that fluid, slippery tone.  Makes the guitar play like it has slinkys on it.
White wire doesn't color the tone as much.
Re: reducing bass
The ones with insulation you can see thru produces the most transparent sound.
Re: reducing bass
So if I understand you all correctly, I'd use bare, uninsulated wire if I wanted my tone to be more raw & metallic?
Aw shucks, guys, now I'm doin it too!
W
W
Re: reducing bass
Makes me wonder whether you had it biased properly when it sounded flabby.iknowjohnny wrote:And nothing changes it. Well, except one thing...i set the amp back to cathode bias as it was a first, and the change was fantastic. The lows are still there but they are no longer causing the tone to lose definition as it was till then.
