I know this is a tube amp building forum; however, I can't help it and just had to tell you about this little amp.  First it has a small foot print but is big in volume.  I found that I like the mix knob in the middle with both the 6v6 and el84 at the same time with the gain knob at 2 o'clock this amp has such good tone for lead runs and found myself playing for 2 hours of classic rock tunes before I finally stopped.  You don't need any pedals with baby and I will find out soon if this is loud enough to use gigging as is without miking.  I used a Dr Z 212 blues open back cab but will build a 1-12 cab for gigging.
Just to let you know I am right smack in to building my Liverpool so I do build amps as well, but nothing wrong with buying a $599 amp to play around with either.  One great sounding amp in my opinion.
						Egnater Rebel 20
