Firefly layout if interested
here is a layout i did for the Firefly amp, about 2 watts; it is done from the version 3 layout which is attached as a pdf. I have not built this amp so check for errors if interested.
Dave
						Dave
									Instructions...I don't need no stinkin instructions
						Re: Firefly layout if interested
very cool thanks for the post. on the layout with the separate power supply card where does the B+1 return?
									My Daughter Build Stone Henge
Well if you download that fireflylayout.pdf it show the complete wiring of the amp. I basically just moved the 3 filter caps to the main board. The rev 3 layout shows all the wiring.
Dave
									Dave
Here is the link to a site that has more info, actually where I got the idea. Just go to guitar amps and on the left column he has a link to the Firefly amp.
http://www.diyguitarist.com/
Dave
Dave
I must be missing something I printed out the layout with the filter caps on the turret and the layout with the power section isolated.  does the B+1 265V power anything other then the OT? that might be what's throwing me.. the squiggly line out, is that just to referance voltage to the OT?   While the B+2 and B+3 have a dedicated in on the turret card.
Just wanted to make sure you didn't leave something out.
Would anyone else be interested in a group transformer buy? if we get 20 of each the cost is almost half of a one off.  just a thought.
I found this schematic.
Dave
						Dave
i'll give it a try and let you know how it turns out i'll use wide turrets so if its a loss I can buy the pcb and still get it to work my daughter really wants to build an amp with me so this could be a fast cheap and neat build.
There is someone on the ax84 website that sells the Firefly PCB.
dave
									dave
Selloutrr,
You might want to check these sites out.
http://www.frontiernet.net/~jff/moonlig ... olume.html
or this
http://www.frontiernet.net/~jff/moonlig ... Power.html
Dave
or this
Dave
Awesome thank you!  I just got the pic of the Rev3 to show up thank you i'm starting it this weekend i'll take pics and let you know how the birth goes.
suggestions for adding a single tone control?
Before you start just make sure my layout matches the rev 3 schematic, if your using it. As I said in my original post I have not built this, I just made a layout for it.
Good Luck,
Dave
									Good Luck,
Dave
I checked the layout to the REV 3 it looks like it matches up!!!  Great attention to detail!!!
I've got a really strong start and have been documenting the adventure with the camera so you can check it out. I'm on track to have this completed over the weekend. I'll try to get some pics posted tomorrow.
Thank you
Thank you
What's the best way to post the pics it seems everytime i post a pic as an attachment it isn't up the next day.
