where are you guys getting your resistors ??
I am trying to fill my order for resistors
is there one location to get all of them ?
I want to use 1 watt carbon films for the board
I am unable to locate the power tube cathode 25w resistor nor the 5 watt black resistors that go to the power tubes
is there a part # list for the resistors ??
thanks for the help
ordering parts is very tedious
dan
Resistors for Rocket (where to buy)
- Ron Worley
Re: Resistors for Rocket (where to buy)
Dan, see my BOM in the Rocket documents sticky in the Files section.
You can get everything except the Panasonic caps at Mouser and Allied Electric....
Get the Panasonics at Digikey..
Ron
Ron
Thanks Ron,
I am working off of your BOM
I am having trouble locating the wire
the part #'s do not show up from MB Electronics
and there are no resistor part #'s
I don't think your BOM lists the 25w cathode resistor either
Dan............
Dan............
- Ron Worley
Dan-
Perhaps you are using an older version of the Rocket BOM- V1.3 has the Cathode resistor and cap.
The wire part numbers are there and always have been....
Ron
Ron
