[IMG:800:532]http://i68.photobucket.com/albums/i5/Mo ... 800pre.jpg[/img]
It works all right, I added an attenuator and a lopass filter at the output for better control, an opamp cab sim, an FX loop. It´s all inside an alu box, including the two transformers wich are in a "sub-box" in an attempt to minimize hum pickup.
Now, I have a hum problem, It´s more noticeable in the low input, in the high input it´s masked by the higher gain, but still there. I tried many things, (input and gain pot wires shielded) mainly moving things apart including the transformers, but the noise doesn´t change. It´s 100Hz hum (220V 50 Hz power here), wich leads me to think it´s post rectifier(s) hum, not mains hum (I already installed UF4007´s but no change)
So, right now i´m thinking two things
1- ground loop(s). What do you think about the PCB layout? It connects all grounds (signal, power)in a way that doesn´t inspire confidence in this regard, at least in my limited knowledge... Solution: put the power supply parts (outlined in red) in a different board and connect it pseudo-star-ground style with only one ground wire to the main board. Will that work?
2- snubber caps across each rectifiers diodes. What value? will that help?
Any help will be appreciated. Thanks
Mostro
