Hi,
I am totally new to the site but I have a couple of questions. When I last had my amp tuned up, my tech told me that the little engraving above the serial number which read Dumble 4 16 77 meant that my '72 Fender Twin had in fact been Modded by Mr. Dumble and was therefore worth a lot more money. The guy who I bought the amp from back in '83 told me that it had once belonged to Stephen Stills, which once I had done some web research on Dumble's doings and his rarified clientele made sense. I do know that the dirty channel on my twin sounds much better than just about any other twin I've ever heard. My question has to do with the XLR output on the back panel of the amp. Until my latest round of Dumble research, I had always thought that the XLR output was for running straight into a live mixing board and/or direct studio recording (it does indeed work that way if you do it BTW). Now however from looking at a lot of the pictures posted of actual Dumble amps the XLR out is clearly labled as for a footswitch, so does an XLR footswitch exist? and what will it do? I'm hoping of course that it will tap into a long unused extra gain circuit. Also provided that I find a working footswitch there's no way I could harm the amp by engaging it right?
XLR Footswitch available for my Dumble Modded Fender Twin?
Jack Gould
Jack
Re: XLR Footswitch available for my Dumble Modded Fender Twin?
The Dumble footswitch frequently used the 5-pin XLR socked/plug. The '150 ohm' marking indicates this is indeed an output jack.
You can tell for sure by opening it up and having a look (or posting a picture).
Looking at how it's placed next to the speaker out, I could guess its a voltage divider taking a line level from the speaker out signal. Next time you have your camera handy snap some pics of the chassis and this forum will do a full analysis of the circuit changes for you, it will be interesting to see if the schematic heaven Dumble mods were actually used in amps like this one.
www.RedPlateAmps.com
