Dlator Values - is this ok
angelodp
Post by angelodp »
Do I have this correct. My build is complete and I tested it with the bulb limiter ( which did not light up ) great. Put a tube in and the LED came on. I should then read voltages at the plates pins 1 & 6
pin 1 - reads 228V to ground
pin 6 - reads 200v to ground
There is a 100k resistor on pin 6
am I ok ??
ange
[IMG:768:576]http://i260.photobucket.com/albums/ii9/ ... G_0504.jpg[/img]
[IMG:768:576]http://i260.photobucket.com/albums/ii9/ ... G_0503.jpg[/img]
angelodp
IT LIVES
Post by angelodp »
[IMG:768:576]http://i260.photobucket.com/albums/ii9/ ... G_0506.jpg[/img]
Its all good .....
FUNK and Heisthl and UltraHooked many thanks
angelodp
Dialing it in
Post by angelodp »
Any thoughts on favored settings for this device. I am having a blast just trying it all. Pardon me if i don't know exactly what this thing does. Any artful explanation of its potential and nuance would be helpful.
ange
Guitarman18
Re: Dlator Values - is this ok
Post by Guitarman18 »
That looks like a very nice build angelodp. I was a little concerned when I saw your original post with your donor chassis but you have transformed it into what looks like some high end studio gear! :D
The d'lator is basically a device for interfacing line level/rack gear into the Dumble amp system, although from some of the threads here it seems to also add an extra dimension to the sound with or without FX. Any more than that I couldn't say, as I'm in the process of building my own as I write!
angelodp
here is my actual build layout
Post by angelodp »
Fischerman
Post by Fischerman »
Nice Nashville! Friend of mine has a sweet original he bought new in the 60's...except for the rotted out polka mute. :lol:
angelodp
64
Post by angelodp »
Yes indeed, this is my first guitar and I can still smell that Gretsch thing when I opened the case. My dad got it for me. I did change out the tuners... still have the original ones. On the D'lite its awesome, although my trustee Tremolux has that vibrato thing thats hard to beat. I add an OCD to that amp and its scarry good.
ange
dogears
Post by dogears »
This is not correct. You should have around 250V-260V on whichever side is the cathode follower and about 230V on the recovery amp side. The tube is wired such that the recovery amp side is fed from the 15K dropping and then the cathode follower from the 100K.
angelodp wrote:Do I have this correct. My build is complete and I tested it with the bulb limiter ( which did not light up ) great. Put a tube in and the LED came on. I should then read voltages at the plates pins 1 & 6
am I ok ??
ange
angelodp
varied values
Post by angelodp »
Thanks dogears, I used a 1.5k resistor instead of a 1.3 at the cathode along with 47uF.... could that account for the difference??
Ange
dogears
Re: varied values
Post by dogears »
Nope...
If you have it wired correct, your PT is putting out lower voltage. I'd suggest changing the string. Maybe 10K/68K. Try and get the recovery amp to 220V-230V and pin 1 of the cathode follower to 260V.
angelodp wrote:Thanks dogears, I used a 1.5k resistor instead of a 1.3 at the cathode along with 47uF.... could that account for the difference??
Ange
angelodp
other readings
Post by angelodp »
where else might I take voltage readings to reveal any errors
ange
dogears
Post by dogears »
Do you have the recovery amp plate connected to the 15K? The order is PS>recovery amp>cathode follower.
Fischerman
angelo,
In general I think it's always a good idea to measure your supply voltages at all nodes (i.e. the + side of every filter cap), all plate voltages, and all cathode voltages. Just listing the plate voltage doesn't tell us much because we don't know the supply voltage and it's often the voltage drops across a resistance that are more revealing. I would also measure the AC filament voltage just to make sure it's in the right range (I just measure each side to ground and look for ~3.15vac).
Then after you measure and record your dc voltages throughout, use Ohm's Law (V=I * R) and calculate the plate and cathode currents. Often they will point to the problem (i.e. too much current flowing somewhere or not enough/none flowing somewhere it should be).
Fischerman
Friggin double-post again.
Why so many double-posts these days when you only hit 'submit' once?
angelodp
correct voltages
Post by angelodp »
Ok, so I did do a re-test and found I was not reading correctly. I set the mains to the device at 135v ( with a friend and his variac ) and found the values for the B+ needed to be at 130v. Then all the values were spot on. With B+ at exactly the right level all the other readings were correct. This then indicates that the first resistor on the DC board is too high. I m advised that the dlator can run with this slightly off value no problem. The normal mains are not at 130 or 135 at any rate.
ange
