Hello
I don't have much experience with amp building but I built a Vibroverb. I think that it came out pretty nice for my first build and I am currently planning my next build with the help of this great forum.
But now to my question. I having problems with the volume pot in the normal channel on my amp. It worked fine the first month and now it is completely shut from 0 - 2 and when it hits 2 it has the same level as it was at 5 when it worked.
It's a CTS pot with a white plasic shaft.
Is this a common problem?
Is there a way to fix this without replacing the pot?
I attached 2 pics of the amp for you guys to check out.
CTS Pot
Re: CTS Pot
I'd replace the pot. For the labor involved to remove the damaged pot, open it up and check that the wiper is making good contact and that the conductor traces arent broken, and then reassemble the whole mess and hope you didnt make it worse, I'd just replace it and call it a day. For a < $10 part my time is worth too much to fiddle with the existing pot.
Re: CTS Pot
Sounds like the wafer the wiper rides on got corrupted somehow.
Usually it is either phenolic or plastic with layer of carbon on it.
I don't know of any fix short of replacing the pot.
But hey, it's only about a $2.00 fix.
I actually like the Alpha pots better for amps.
Re: CTS Pot
Ok, I have checked both the supply stores here in Iceland and neither have this value. I'll just wait until I order from USA for my next build.
Karl Fridrik
Re: CTS Pot
Ah, you didn't mention you were in Iceland.
Sourcing is difficult?
Got any Telefunkens over there?
