I solved my Les Paul dilemma with a total GAS buy. About 5 years ago I saw a similar Les Paul for $995 and didn't act quick enough. Could let this one go.
The frets look to be newer and slightly oversized, which is fine by me. The nut has been filed down too far, so the action is set high to compensate. A new nut and setup will make this baby perfect.
I have a set of cream covers on their way. A little dirt, some steel wool, a couple of gouges and they'll look perfect on this axe Who needs to $50 for aged covers....not me
It still plays really nice and the neck is very SWEET!!!
Is it the super thin style neck? My fathers 73 is thinner than any "60's slim taper" Gibson I've come across.
Does the binding come up the end of the fret a little or do the frets sit over the binding on the fretboard? I'm not sure if you know; but thats how you can tell if they are originals or new (usually).
The neck is pretty wide, with a 60's taper. Not too slim.
The binding does come up a little over the ends of the frets, but their are small stress fractures in the binding at almost every fret. They also seem to be a bit oversized frets.
Stress fractures aren’t necessarily an indication of re-fretting. My '94 with originals have stress cracks; I've also seen a few 60's 335's and SG's with stress fractures in the same spots.
They started putting medium jumbos around that time period as far as I know. But if you have binding that wraps up the side of the fret slightly, it was either a good re-fret or its still original, but from the shape of the finish. I think it was probably just a good re-fret.
Congratulations Dart. You're going whole hog. Here's what you'll sound like with P90s in a LP. This of course is the Special not the Deluxe, but you should sound about the same.
GoodLookin Lester Dart, I gotta 70 Goldtop with Mini Bucker's and will never turn it loose, mine's stock and it will stay that way, I got a Cheapie LP JR copy with Duncan P-90's in it that just kills for the low buck's i got in it, it's my tester, I like havin one i can experiment with !
Enjoy !,
Johnhenry
