Moderators: pompeiisneaks , Colossal
chocopower
Posts: 51 Joined: Fri Jun 29, 2007 8:34 am
Post
by chocopower » Tue Nov 20, 2007 12:39 pm
Hi!
Just a question..
I want to add a local feedback loop to V1 of my Pro-Reverb clon.
In layouts i saw a 22M resistor and a .05uf cap.
But.... What´s the reason for the 200K resistor (some times paralelled with a 390pf cap)?
Could i ignore it? Is that resistor part of the local feedback loop?
Best regards from spain, and sorry for my english.....
mlp-mx6
Posts: 1111 Joined: Sat Feb 04, 2006 4:24 pm
Post
by mlp-mx6 » Tue Nov 20, 2007 12:47 pm
No, do not skip that. That resistor is the grid stopper for that stage. The small cap is a "bright" cap for that grid stopper.
Me: Just one more...
Fischerman
Posts: 819 Joined: Thu Dec 07, 2006 3:47 pm
Post
by Fischerman » Tue Nov 20, 2007 12:52 pm
If I'm understanding your question correctly...the 220k is the grid stopper for the grid of the next stage and it is bypassed with a cap (390pF or 500pF). But if the schematics I've seen are correct...that 220k and cap are not 'inside' the loop when the feedback loop is for CL2. The 220k and cap are in the loop when the feedback loop is put on the Return stage for a Dumbleator...but the cap value for the feedback loop is different as well (.22uF instead of .05uF).
Also note that the resistor value can be as big as 44M and at least as low as 22M maybe lower.
chocopower
Post
by chocopower » Tue Nov 20, 2007 12:59 pm
I want to solder it to a 3 position-center off swicht with another 22M resistor... soo
1.- F.Loop On. 22M
2.- f.Loop off
3.- F. Loop On. 44M
My question is if the 220K/390pf will pair affect the sound in the bypass mode..
thanks for your fast positive feedback loop....
chocopower on Tue Nov 20, 2007 3:29 pm, edited 1 time in total.
Fischerman
Post
by Fischerman » Tue Nov 20, 2007 1:03 pm
What I'm saying is that the 220k and the cap are part of the 'basic circuit'...regardless of whether you use the feedback loop. Those parts are not part of the loop...they're just part of that particular preamp circuit.
chocopower
Post
by chocopower » Tue Nov 20, 2007 2:38 pm
so.... if i´m only interesting in the preamp feedback loop, i should skip them. isn´t?
Fischerman
Post
by Fischerman » Tue Nov 20, 2007 2:49 pm
Yes, just disregard the 220k and cap. They are not part of the feedback loop.
mlp-mx6
Post
by mlp-mx6 » Tue Nov 20, 2007 3:23 pm
For the purposes of the feedback loop, yes, they are not a part of THAT circuit. Do not leave them off the tube socket, however. They are much more important to your tone than the feedback circuit.
Fischerman
Post
by Fischerman » Tue Nov 20, 2007 3:28 pm
mlp,
Very important part of choco's op:
I want to add a local feedback loop to V1 of my Pro-Reverb clon .
Those just go straight from the volume control to the grid of the second stage...no stopper or cap.
mlp-mx6
Post
by mlp-mx6 » Tue Nov 20, 2007 3:36 pm
Y'know, that IS important! Thanks for helping me see what I missed.
jerrydyer
Posts: 38 Joined: Mon Nov 19, 2007 9:47 pm
Post
by jerrydyer » Wed Nov 21, 2007 6:22 pm
what exactly does that 22m loop circuit do? thanx
llemtt
Posts: 332 Joined: Sat Feb 04, 2006 3:13 pm
Post
by llemtt » Thu Nov 22, 2007 5:45 pm
it's a negative feedback loop, so does whatever negative feedback does: reduces distortion, improves freq response, lowers output impedance,...
the right question is: why is there?
teo
chocopower
Post
by chocopower » Fri Nov 23, 2007 2:41 pm
llemtt wrote: it's a negative feedback loop, so does whatever negative feedback does: reduces distortion, improves freq response, lowers output impedance,...
teo
I don´t know.....but i´m gonna install it in 2 hours and monday..... i´ll be back.....whit a lot more questions!!!
Thanks everybody for your help. This forum (and Ampage, of course) are the best tecnichal support in the world!!
ahhh!!
This is my amp layout with this mod in V1...
614]
http://i101.photobucket.com/albums/m74/ ... AYOUT5.jpg [/img]
chocopower
Post
by chocopower » Mon Nov 26, 2007 7:58 am
Ok....
mod is done.......and only a subtle effect is audible when i move the swicht... and the most evident change is in the 22M position, not in the 42M!!!!
I had mount the swicht in the front panel and the cap and one of the resistors in the main board. The other reistor is pick in the swicht.
Should i mount them direct to the V1 pins, as showed in the original mod, for a more significant effect?
best regards from Spain...
mlp-mx6
Post
by mlp-mx6 » Mon Nov 26, 2007 12:15 pm
Your description sounds exactly correct. It is a subtle effect.
22M offers more feedback than 44M, so I would expect more effect at that setting.
Closeness to the socket will not make a difference, except maybe for noise - but you did not mention noise. Sounds like things are just as they should be.
