SIR #36 Cap question
Marshall Amp Discussion
lgehrig4
Post by lgehrig4 »
I'm modding a 2204 clone to #36 and I have a question about this 16u cap. I only see the cap in this layout, but not the schematics. What does it do and if its a good idea to include this, do you think 10u or 22uf in place of 16u would do fine? I don't have a 16u :)
Roe
Re: SIR #36 Cap question
Post by Roe »
yes a hi-gain amp needs proper filtering indeed. 10-22uf is fine really.
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Post by Stevem »
A good rule of thumb for a high gain amp is to not have any more then two gain stages powered off of just one filter node.
Use the 22 uf .
lgehrig4
Post by lgehrig4 »
Thank you both!
lgehrig4
Post by lgehrig4 »
One last question. What would the minimum voltage rating for this cap? I just realized that the one I have is 25v
syscokid
Post by syscokid »
450v to 500v
Greg
syscokid
Post by syscokid »
lgehrig4 wrote: Tue May 27, 2025 1:18 pm One last question. What would the minimum voltage rating for this cap? I just realized that the one I have is 25v
450v to 500v
Greg
syscokid
Post by syscokid »
Double post!!
Greg
syscokid
Post by syscokid »
Triple post!! I’m on a roll this morning with too strong coffee!
Greg
lgehrig4
Post by lgehrig4 »
Thank you! I ended up finding a 16u 500 F&T in my stash. Larger than I planned for but I found a nice spot on the side chassis wall.
