I'm building this amp using an Amplified Nation chassis and boards and, for the most, following the most recent iteration of the layout from the A Collection of #124 Information (Schematics, Layout, etc.) thread.
The amp I am building will not utilize the 10uf/10uf cap and the power supply is different than the layout. I have a few questions about the board. Attached is a photo of the power supply(not mine but the same) and screenshot of the of the section of the board where I have these questions.
1. In the layout there is a red wire running from the 2nd 100K resistor from the 2nd pair, that runs under the board to the 10uf/10uf cap. Since I'm not using this cap should I run this directly to the power board or is there something else that I need to do?
2. Am I seeing this right. It appears that the brown wire from the master center log runs to a rear jack, but instead of running straight through its two separate wires soldered together on tjhe board. Any reason for this?
3. Where does this grey bias wire run to? The center lug of the bias knob? If so am I adding a 220K resistor between the wire and pot? It just says 220k for some reason but there is no resistor drawn.
4. Where does the green wire from the .02uf go? It just cuts off as it intersects with the blue wire from relay, but if green/blue were to be connected I would imagine this would be drawn differently.
5. This is more out of curiosity. Why does the ground from the 1uf (I'm using tantalum) cap run under the board to the jack rings instead of taking a short trip to the ground bus?
Bonus question not numbered in the layout
I appreciate in advance any help I can get. I'm slowly trying to learn to read schematics at the moment its a bit much for me with an amp like this.
Thanks!
Jeff
