I'm building an AA164 Princeton Reverb and having some issues with noise/shutoff at elevated volumes. I'm building to Fender's schematic and using my own layout, modifed from Fender's. Everything works and sounds good at lower volumes, it just goes south as you turn up. Here's what I have going:
TESTING WITH FULL AMP: As you turn up the volume control,at some point a ragged distortion starts to happen, particularly with a higher input signal (i.e. as you dig into the strings harder). If you turn it up even more this becomes a squeal/oscillation, This is exacerbated by maxing out the treble control, i.e. it happens earlier if it is all the way up.
TESTING WITH REVERB DRIVER REMOVED: At some point I decided to test it with the 12AT7 (V2) removed and got different results. Now there was no oscillation, but if both the Treble and Volume controls are all the way up it goes silent. I should mention that I am testing without the reverb pan connected.
Deviations from stock:
- 470K grid stopper to PI adeed, per Rob Robinette suggestion
- 6.8K resistor in tone stack replaced with 25K Mids pot
- LarMar master volume added
- shielded wires used for girds of V1
Here's the Fender schematic i'm using: https://schematicheaven.net/fenderamps/ ... aa1164.pdf
And here's my layout, let me know if there are questions:
Anyone have ideas what could be the problem or where to look? Am I potentially looking at multiple problems given that its different with the Reverb Driver installed?
THANKS FOR ANY INPUT.
