I've just had it gone over, recapped as necessary. Don't think anything was done wrong as the rest of the amp works fine but the top boost switch apparently has no effect... ?!?
Apparently, top boost in these amps works by shorting R46 (1k)... and the switch has been tested/works, as does C25 (1uF). FWIW, another well-regarded Vox tech says his experience is similar with one Defiant he encountered...
Pre-amp schematics for reference. Photocopy of an original:
An older, slightly cleaned up version
Normal channel in question:
Presuming it's not a factory/schematic error, outside of checking the switch, how do I go about troubleshooting and ultimately resolving this?
