I'm looking for some 20mm inline fuse holders that can be installed in the secondary windings of power transformers.
Anybody know of a quality, small sized holder I can use. Where to get them? I don't care about how they look. Want them to function and last.
What about different types of fuses than the 20mm? Anything else worth considering?
Fuse Holder Supplier
- dragonbat13
Mark Clay
Amature/Hobbyist/Electronics Hoarder
Re: Fuse Holder Supplier
Ah, fuse holders... the dark underside of fuse protection.
Mouser is my favorite supplier. Try this link. The cheapest is by Shurter, $1.30, and they typically don't make junk.
https://www.mouser.com/c/circuit-protec ... rt=pricing
Click the "datasheet" link to see the manufacturer's datasheet for the ones you''re thinking about.
Mark Twain
Mark Twain
- dragonbat13
Well shit.
I ordered some fuse holders by schurter but they are marked 32v x6.3a size.
I was wanting 20x5 mm.
Reading in Merlins book, he states the most common sizes are 20x5 mm and 32x6.3mm
Are 32 x 6.3 mm the same as 32 x 6.3a? Some places I see 32volt x 6.3amp.
This is quite frustrating. I am trying to get the easiest type of fuses to get for my side of the pond and once again it's gotta be all out of wack. I mean one rare case where the US decides to use metric sizing and the other side of the pond uses something different
Anyway, I may be totally wrong about that.
Is a fuse holder with the package marked 32V x 6.3A capable of using 20x5 mm fuses? Is a fuse holder marked as 32V x 6.3A the same as 32x6.3mm (a size I got from merlins book which may be a typo)?
Mark Clay
I think this is what you want: https://www.mouser.com/ProductDetail/Li ... p6Dw%3D%3D
- dragonbat13
Yeah.
I need to start working. With mousers site anyway. I have been using digikey for everything.
Mark Clay
DigiKey has that part too. https://www.digikey.com/en/products/det ... 274Z/29453
Yeah, either of the items Martin notes should work.
I sympathize with you. Picking the right one of electrical connectors can be daunting. The numbers overlap. The commonest size of fuse in the USA is 1 1/4" x 1/4", which is 32mm long by 6.3mm diameter. The 20mm long, 5mm diameter size is becoming ever more common. Near as I can tell, it's an accident that Schurter has a fuse series that's rated for 32 volts and 6.3 amps electrically that also has physical sizes of both 32mm x 6.3mm and 20mm x 5mm depending on which model of that fuse series you pick.
But reading the data sheet more closely, the 32V rating on the Schurter is marginal. The Littlefuse models Martin mentions are rated at 350V, and are a better choice.
I don't like in-line holders, personally. I don't like the fuses in plastic lumps waving around in the air I would use something like these:
https://www.mouser.com/datasheet/2/240/ ... 372316.pdf
The solder terminal version (05200004Z) mounts to the chassis with one screw. It provides a mechanically fixed position for the wires to connect. The down side is that it's nearly US$2 per holder and eats up chassis space that needs to be accessible.
If you consider these, be sure to get the panel-mount version, not the PCB mount version.
Mark Twain
Mark Twain
Digitkey isn't vary far from me but I end up finding stuff on Mouser easier?
- pompeiisneaks
- Site Admin
Can't agree more, I have ordered from both, but always find stuff faster/easier on mouser.
~Phil
tUber Nerd!
