The problem i'm having is that it bleeds signal with all of the pots set to 0 on both channels, as well as on the reverb/tremolo effects. It happens when the input cable is plugged into either channel, and interestingly adjusting the trebble pot does impact the loudness of the signal.
I verified that there's no signal coming through the loudness pot, and even with the output from that removed the signal comes through.
I did some spelunking through the wiring with an osciloscope and it seems that it's crosstalk from a preamp tube, V2B in this case (input 2). If I disconnect the grid from the tube (pin
I tried a bunch of other things without anything conclusive, like checking the filter caps (replaced by a previous owner), isolating the channels, unhooking the effects input. The final filter that runs the 250V preamp bus does have a little bit of the test signal on it, but mostly removing it with an additional 40uf cap didn't change the signal bleed at all. There's also a ton of RF noise in that area, i can clearly see the test signal if the probe is anywhere near the components in the preamp stage without actually touching them.
Sorry for the long spiel, but I'm out of ideas. My googling has been inconclusive, it seems like it's not an uncommon problem without any great fixes. I've seen people suggest trying different tubes, but swapping them around made no difference.
Thanks for any suggestions/info!
TL;DR: amp still amplifies input at 0 everything, seems to appear out of thin air right before the second preamp tube grid pin.
