NTE resistors
sergio
NTE resistors
Post by sergio »
Has anyone bought resistors from NTE lately?
I bought many "metal film resistor" but I have been sold metal oxide resistors. attach pics of 68kohm for example.
on the left metal film purchased a few years ago, on the right the order just received.
honestly to me they don't look like the same resistor.
very strange, the packaging shows the same code.but resistors are different.
I wanted to know if anyone had this surprise like me, and if it solved it somehow.
thanks for your help
Sergio
www.sae-audio.it
Handmade tube amplifiers inspired to Dumble sound!
sluckey
Re: NTE resistors
Post by sluckey »
Packaging changes all the time with everything. I'd say they are the same.
Re: NTE resistors
Post by Stevem »
The ones on the right sure look like MO to me.
If you take the time to grind a opening thru the ceramic color band outer layer of one of each you will know right away!
The make up of a metal film type is such that the resistance material is like a gray spiraling wrap from end to end on a core material.
thetragichero
Re: NTE resistors
Post by thetragichero »
Stevem wrote: Fri May 27, 2022 8:58 pm The make up of a metal film type is such that the resistance material is like a gray spiraling wrap from end to end on a core material.
i watched one of these glow BRIGHT orange and smoke in a malfunctioning kustom amp. it's what sold me on metal oxide resistors in higher current applications
TUBEDUDE
Re: NTE resistors
Post by TUBEDUDE »
Higher current applications may benefit by using higher wattage metal films also.
sergio
Re: NTE resistors
Post by sergio »
Inside they look the same resistor. Only the outer cover changes.
www.sae-audio.it
pdf64
Re: NTE resistors
Post by pdf64 »
Yes, it may just be that the surface coating is unglazed and so matte in appearance, rather than glazed and so shiny.
thetragichero
Re: NTE resistors
TUBEDUDE wrote: Sat May 28, 2022 7:24 am Higher current applications may benefit by using higher wattage metal films also.
oh definitely. my point was mainly based on failure mode. a metal 'coil' glowing hot orange can wreck a lot of stuff
SoulFetish
Re: NTE resistors
Post by SoulFetish »
I think they label those newer ones as flameproof, correct? I think it refers to the coating
SoulFetish
Re: NTE resistors
They list their 1/2W resistors as metal film. 1,2, & 3W types as Metal Oxide
