I've read few guides and i think i got some things (impedance, etc.).
I did not get if both in series and in parallel both speakers (in a 2x configuration) receive the same signal from the amp simultaneously.
I'll try to explain this using the example provided by a guide from Koch Blog:
In series, the signal goes first into one speaker and then into the second, right?
If so the second speaker receives an alterated signal than the one entering into the first speaker, right?
How the signal differs? (does it get lower or higher or what?)
I'm asking cause i am curious about speaker distortion.
I've read that Celestion Blue VOX AC30 are wired in series. Being 15w speakers they do distort a lot? Or one more than the other? Or how does it work?
For example, if i have a 20w head and a 2x12'' cabinet - one being 30w and the other 15w - does the behavior change if i wire them in series and i change which speaker get the signal first (if there's one who gets it first)?
Last question: what you think about combining very different speakers? Like a Jensen and an Alnico Blue?
Thank you very much for your time and i wish everyone a nice day!
Edo
