I'm trying to get a better understanding of the current draw in the AC load line. Below is the AC and DC load lines of a 12AT7 gain stage with 18k plate and 470R cathode, fed from a B+ of 310V. The AC load is a 600 ohm (@ 1kHz) reverb tank. First of all, please ignore the fact that the AC load line grossly exceeds the max dissipation line.
According to Merlin and a few others, the extra current draw that the AC load represents is sourced from the coupling cap, but I don't understand to what extent this applies to. As far as I can see, Ohm's law is working perfectly fine as long as the AC load line crosses the 0V grid line at or below the max current that the plate resistor will pass at full B+ voltage: I = U/R = 310/18k = 17.2mA.
Now, what happens when the AC load line crosses the 0V grid line at 24.5mA? The required voltage for the 18k plate resistor to pass 24.5mA is 18k*24.5 = 441 volts. The theoretical plate resistor's resistance at the point where the AC line crosses the 0V line equals U/I = (310-210)V/24.5mA = 100V/24.5mA = ~4.1k. None of this makes any sense to me, since all current in the circuit must pass through the plate resistor, and the B+ is only 310V.
Will the tube run out of headroom and clip the output at 17.2mA no matter what the grid voltage is?
