Questions about the DCCF found on the SSS:
1) How would you modify this circuit to use 2x separate bias trimmers (one for each side)?
2) Thoughts/personal experiences swapping in directly LND150 for the 12AX7 here?
TIA
It was my understanding that a cathode follower is near or under unity gain, and for recovering losses from the tone stack and matching impedance etc. Therefore, it would seem to me that it's doing very little if anything to 'color' the sound and is functioning as a 'bridge' between segments of the circuit. They perform exceptionally linearly (per the valve wizard) and therefore to me seem like a perfect place to replace them with a mosfet if one should choose to do so? No? It seems that other tone shaping parts of the circuit would definitely not be optimal like gain stages, or phase inverters that drive hard into power sections, etc are very optimally chosen as tubes....
Tube CF defenitly has some added compression/harmonics beside the unity gain.pompeiisneaks wrote: ↑Wed Dec 09, 2020 8:22 pmIt was my understanding that a cathode follower is near or under unity gain, and for recovering losses from the tone stack and matching impedance etc. Therefore, it would seem to me that it's doing very little if anything to 'color' the sound and is functioning as a 'bridge' between segments of the circuit. They perform exceptionally linearly (per the valve wizard) and therefore to me seem like a perfect place to replace them with a mosfet if one should choose to do so? No? It seems that other tone shaping parts of the circuit would definitely not be optimal like gain stages, or phase inverters that drive hard into power sections, etc are very optimally chosen as tubes....
Or am I mistaken?
~Phil
Could you explain how/why? If it's operating in a completely linear fashion and not amplifying the signal, what causes compression in a non driven tube that's in it's linear section? I thought the compression is caused when a tube starts getting out of the linear zone, and is amplifying past it's optimal 'linear' range. I also am under the impression that the 'tone' from a tube comes from the non linearities, that cause the other harmonic distortion etc. If the stage is in a non amplifying, very linear operating point, how does it color it? I honestly want to have detail/data that explains this. I trust you're probably right, but just because you say it is so, doesn't mean it is so. And no offense meant, I'm just looking for knowledge and understanding, and although I trust you, I still don't understand the 'why' and want to.erwin_ve wrote: ↑Wed Dec 09, 2020 9:58 pmTube CF defenitly has some added compression/harmonics beside the unity gain.pompeiisneaks wrote: ↑Wed Dec 09, 2020 8:22 pmIt was my understanding that a cathode follower is near or under unity gain, and for recovering losses from the tone stack and matching impedance etc. Therefore, it would seem to me that it's doing very little if anything to 'color' the sound and is functioning as a 'bridge' between segments of the circuit. They perform exceptionally linearly (per the valve wizard) and therefore to me seem like a perfect place to replace them with a mosfet if one should choose to do so? No? It seems that other tone shaping parts of the circuit would definitely not be optimal like gain stages, or phase inverters that drive hard into power sections, etc are very optimally chosen as tubes....
Or am I mistaken?
~Phil
his book also discusses the Mosfet substitutes for cathode followers (LND150)JD0x0 wrote: ↑Thu Dec 10, 2020 5:34 am ValveWizard has a pretty solid write up on DCCF and explains how the 'flawed' operating points contribute to the
performance, which many find desirable, in guitar amps.
http://www.valvewizard.co.uk/dccf.html# ... to%20cause
With flawed operating points?Roe wrote: ↑Thu Dec 10, 2020 7:59 amhis book also discusses the Mosfet substitutes for cathode followers (LND150)JD0x0 wrote: ↑Thu Dec 10, 2020 5:34 am ValveWizard has a pretty solid write up on DCCF and explains how the 'flawed' operating points contribute to the
not that I'm aware of noerwin_ve wrote: ↑Thu Dec 10, 2020 8:55 amWith flawed operating points?Roe wrote: ↑Thu Dec 10, 2020 7:59 amhis book also discusses the Mosfet substitutes for cathode followers (LND150)JD0x0 wrote: ↑Thu Dec 10, 2020 5:34 am ValveWizard has a pretty solid write up on DCCF and explains how the 'flawed' operating points contribute to the
