the pandemic event gives me the time to build again a tube power amplifier and I'd like to share it with you, since I was following this forum long time before my subscription.
In the attached rar file you can find a block diagram and everything is needed to build my amp (I think
In the EF86 channel I've used a MOSFET to regulate the G2 voltage and compress the penthode curves, in this way the gain decrease and overdriving the channel will give a nice compression/saturation.
The EF86 stage have no catode bypass cap, for two reason:
1) I'd like to make a clean channel where part of the gain is given by a 12AU7 or 12AT7 thus maintaining the penthode brillance character.
2) using bypass capacitor this preamp becomes unstable, no matter how many damping capacitors you would add, I don't know why and I don't want to know because without this cap the sound is what I want to get
I had some problems with the power supply transformer, it has high leakage inductance and generate orrible spike noise in the audio frequency 100Hz modulated, I ended up to use SiC diode instead of classical 1N/UF5408 and a big RC snubber on the high voltage tap, this is reported on the schematic but if you don't have this problem the snubber can be omitted.
I will change the power supply transformer later.
Since I'm a big fan of PCB I've done also the power stage on it.
In the power stage PCB there is also the gain recovery and the cathode follower that enables me to use a 100k master potentiometer, this is a plus because the master volume is on the front panel and with low impedance it will not be affected by crosstalk.
The PCB comprend also a relè switching designed to switch between the two channels and to ON/OFF the loop, when one channel is not used the relative input is grounded.
This is the block diagram: This is the result: (samples as soon as possible)
Thank you for the usefull information and topics on this forum, I'm glad to contribute to it.
Regards
luix
