2-channel Fender 6V6?
Hello,
I'm getting started on a Deluxe Reverb variation (single channel, reverb - no trem, normal 6V6 power section).
Then thought that I could consider adding 2 tubes (PT would have enough juice) and build a 5f6-a preamp as a new channel.
Not entirely sure how to combine the 2 channels though:
- LTP: could have done directly into LTP like a DC30 but want to keep the negative feedback so that seems challenging
- Mixing resistors: Deluxe Reverb has these to begin with. I'm not sure how the cathode follower of 5f6-a which is the last stage would react / interact with other channel
- Manually switch channels: not a particularly elegant solution it seems...
- Put the NFB elsewhere.. could have it on last gain stage of Deluxe Reverb preamp. Not sure where it would go into 5f6-a preamp. That would certainly change the tone...
Any views / pointers / existing schematics appreciated!!
Or is that just a silly idea and I should just build a Deluxe Reverb + a Bassman?
Thanks all!
As an intro, I'm a new forum member (although I have been reading posts for a while now). Built a few guitar amps now and want to challenge myself with a more advanced build
Thanks all!
Re: 2-channel Fender 6V6?
Ok, thanks
I'm told separately that 3-input LTP actually seems to work as well. Relatively easy to try both
Based on your experience, does having 2 preamps / channels into 1 power section have a negative impact on tone vs. having single channel amps?
I don’t think you can separate out the power amp and the preamp like that; the whole thing (inc chosen speaker and cab types) is an integrated system.
eg the 5F6A without a presence control ain’t a 5F6A; the treble control would naturally need to be set higher, resulting in a different system response than a lower treble with any degree of presence boost. May be perceived as a hollowed out tone.
Likewise for the high pass filter between pre and power amp of an AB763 deluxe.
You're absolutely right - it won't be a 5f6-a, just a variation. I do plan to have a presence control though!
I was going to build 2 single-channel amps with a relatively similar 6V6 power section - a single channel Deluxe Reverb + a variation of a 5f6-a. Conscious neither will sound exactly like the real thing by design but I'm pretty sure both will sound great. I would save a fair bit of cash by building a 2 channel amp instead.
Most iconic amps arguably have 2 channels so I don't think that's detrimental to the tone in itself. Just unsure about the 5f6-a channel this isn't a 2-channel amp to begin with.
Let me rephrase the question: would the tone of the 5f6-a be affected if I combine the two preamps into one amp vs. building 2 separate amps?
Are there plans to use this amp to gig with, and if so will it be thru 1-12" which I concider the minimum to gig with or will you be running more?
Hi
No plans to gig it, just home use - will go through a 2x10 cab with NOS AC10-type ELACS (at least for now)
Also why I'm going for 6V6's
thanks!
thanks!
Here is something to consider. Just a DRAFT schematic. I've not built this. I've attached an editable SCH schematic CHECK for ERRORS!
You'd use an A/B/Y box for the switching.
With respect, 10thtx
That's pretty much exactly what I'm planning to build! thanks
I'll try both mixing resistors + 3-input LTIP and see what sounds best
IF you had a PT that is 140ma (or more) and is 300-0-300 using a solid state rectifier, you'd probably get about 420v on the plates. JJ 6V6's can easily handle that OR you could consider 5881's.
Or JJ brand 7591 tubes which have the same specs ( different pin out ) as 5881s and sound far better when driven hard then any Sovtec 5881 ever willing!
That also an excellent point
Was planning to use this
http://www.classictone.net/40-18028.html
http://www.classictone.net/40-18028.pdf
But does it have enough juice to power all these tubes?
- Rectifier (GZ34 or 5A4GB)
- 2x6V6GT
- 2x12AT7
- 2x12AY7
- 1x12AY7
Otherwise this definitely has all the power one needs but will also sound less "tubey". And the 710V HT is aggressive...
http://www.classictone.net/40-18029.html
http://www.classictone.net/40-18029.pdf
- 2x6V6GT
- 2x12AT7
- 2x12AY7
- 1x12AY7
Seeing as in that schematic shown the OT has a 8 ohm tap, the amp would sound a good amount better if those 4 drivers where rewired to provide a 8 ohm load.
The cab I have is actually 8ohm. I'm planning to use a 4/8/16 ohm OT - 20W Classictone Fender-style
Biggest question to me is does PT have enough power though
