Simplified ODS-101-HRM clean section schematic
esist
Post by esist »
Hello,
I am building up a Dumble ODS 101 HRM preamp. To reduce the number of switches and controls of the clean section, I simplified the Skyline Tonestack by removing the PAB, Deep & Bright switch so that they should be all statically off.
My starting point was the ODS-101-HRM Rev1.4 schematic from this forum.
The outcome looks as follows.
Now I get far too much bass compared to the original schematic which I have already successfully built. Also a the treble pot has a much too strong effect on the overall volume.
I am not sure if by removing the Deep circuit completely I did the right thing to have a configuration that is "Deep off".
Could please someone help me by a review of what I did and point to any findings ?
Any help is appreciated !!
Thanks to all of you,
esist
The beauty of simplicity !
Re: Simplified ODS-101-HRM clean section schematic
Looks ok to me. Maybe you have a wiring error somewhere? The only change I would make is to the mid boost switch wiring, making so that it shorts the 390p cap when mid boost is off.
sonofmickel
Post by sonofmickel »
Nice first post!
Did you ever figure out the "too much bass" problem?
