Tweedle Dee Champ build
Oddvar R
Post by Oddvar R »
I am rebuilding a Epiphone Valve Jr 5w amp that I have into a Tweedle Dee Champ. I plan to take out the board and replace it with a build as laid out in the schematics section here. The Jr PT has a 260v secondary, and I must admit I don't quite understand what to look for in the PT. What actually constitutes a workable PT in this context and any context for that matter. It seems like the champ has one 6v6 power tube, the PT was meant for El84. The OT is a Classic Tone 15w.
I also have a choke 8H 100ma. What does this actually mean? And is it usable in this build?
10thTx
Re: Tweedle Dee Champ build
Post by 10thTx »
Regarding the PT, you need to know what the ma current draw is of the power tubes and what the working range & max voltage is. Look at the tube data sheets for the tubes you are using. I've attached a tube data "cheat sheet" that may be useful to you.
http://tdsl.duncanamps.com/tubesearch2. ... bmit=Query
Keep in mind that if your PT doesn't produce similar voltage on the power tube plate that it may not sound the same? It still may be a nice sounding amp but just different.
With respect, 10thtx
