'63 Bassman
Fender Amp Discussion
Colossal
'63 Bassman
Post by Colossal »
Hi guys,
I happened upon a video of a gentleman playing a (real) '57 Goldtop with P90s into what turns out to be a '63 Bassman. Very little of the amp was visible in the video, but I'm pretty sure it's a head on top of a 2x12. After some inquiry, the reply I got about the amp was "1963 Fender Bassman. Transitional model with smooth white tolex, with raised logo and Blackface (versus Brownface) control panel". The tone was amazing; very piano-like with a bouncy, clear, chimey, and percussive attack :) Am I correct to assume this is the 6G6-A or B circuit?
Re: '63 Bassman
It may be this one: https://www.creamcitymusic.com/vintage- ... yback-amp/ But to be absolutely sure you might have to look inside.
Colossal
Re: '63 Bassman
Post by Colossal »
martin manning wrote: Thu Sep 26, 2019 9:16 pm It may be this one: https://www.creamcitymusic.com/vintage- ... yback-amp/ But to be absolutely sure you might have to look inside.
Thanks Martin. That's a sweet amp.
Re: '63 Bassman
Post by Stevem »
I have worked on , played and heard a bunch of these SS rectified Bassmans of that year and the ones that had or still have there original RCA output tubes and came with Jensen C12n Drivers and not the Oxford Drivers sound far better as you open up the amp!
Re: '63 Bassman
I have a 1962 Bassman head the tag shows 6G6A but the amp has been to hell and back but will be blonde again. Cost $379 at a local pawn shop.
Roe
Re: '63 Bassman
Post by Roe »
nice amps but its even better to build a new one. I recommend
- a mid controll, e.g. 100kA pot
- removing or decreasing the 470k mixer resistor
- decreasing cap values somewhat for tighter bass.
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Colossal
Re: '63 Bassman
Post by Colossal »
Roe wrote: Sat Sep 28, 2019 4:30 pm nice amps but its even better to build a new one. I recommend
Hi Roe,
I agree. This would be a nice project. The amp with that Les Paul sounded bubbly and very musical! I would likely just make it a single Normal channel only, no Bass channel. For the mid control, you suggest 100kA? Would you do this Dumble style? Or did you mean 10kA to replace the 6k8 mid resistor?
How about adding a one-tube reverb circuit? Maybe insert it just after the tone stack and returning after the second stage? or insert it after the second stage and mix back in before the PI?
Re: '63 Bassman
I did the same thing when I built a single channel Deluxe for my cabinet guy added middle pot a 100KA because he likes more mids and that was the value David Allen used in one of his amps.
Copy copy copy
Roe
Re: '63 Bassman
Post by Roe »
Colossal wrote: Sun Sep 29, 2019 2:47 pm
Hi Roe,
I mean a 100k audio pot instead of the 6.8k resistor. I prefer to add reverb and delay after the amp, using either a fryette power station or adding it during mixing in the studio.
As for cap values, I think 2.2uf on the first gainstage cathode is enough for guitar. on the second gainstage 2.2uf also seems to work well. However, the 500pf coupling cap could be increased to 1000 or 1500pf, whereas the .1uf in the phase inverter could be decreased to .022uf or .033uf
4x12" w/H75s
Re: '63 Bassman
Post by Stevem »
If you going to spend the time to add a mid pot to the tone circuit then I would build a tone circuit that lets you boost the Mids, and not just cut them as the shock Fender mid pot does in there tone curcuit.
The only way to get a mid boost out of the stock 2 knob tone circuit is to crank up the volume and turn down the bass and treble to very low levels!
Colossal
Re: '63 Bassman
Post by Colossal »
Roe wrote: Mon Sep 30, 2019 7:53 am I mean a 100k audio pot instead of the 6.8k resistor. I prefer to add reverb and delay after the amp, using either a fryette power station or adding it during mixing in the studio.
Thanks Roe. So a 100kA would act as a Tone Stack Lift if replacing the 6k8 mid resistor. I agree on the lower bypass cap values; plenty of bass. I prefer to keep the notes defined and punchy, not flubby or bloated.
Very nice 6G6A, Mark! What a great find at a great price.
brewdude
Re: '63 Bassman
Post by brewdude »
Do you guys have a preference for 6g6a or 6g6b?
Re: '63 Bassman
I do not know myself the tone difference but Brain Stetzler uses the 6g6b circuit.
I bought another chassis/faceplate to build the new one 6g6b and the pawn shop find 6g6a.
Colossal
Re: '63 Bassman
Post by Colossal »
M Fowler wrote: Mon Sep 30, 2019 10:34 pm I bought another chassis/faceplate to build the new one 6g6b and the pawn shop find 6g6a.
Mark,
Do you know of anyone carrying a 6G6 chassis right now? I looked at Marsh, Allen, Mojo...no dice.
Re: '63 Bassman
Dave,
I got my chassis/faceplate combo here: https://www.ebay.com/itm/Brown-Bassman- ... .l4275.c10
However, I see separate brown 6g6 faceplate but no chassis. The blackface chassis is same size just missing the presence pot hole.
I measured my BF Bassman to the compare with the Brown Face 6g6 and they are the same just missing the presence pot hole.
You can get a Blackface chassis from seller above or from Zachmdhunder on ebay.
