Alter Preamp Input Impedance
jimbopicks
Post by jimbopicks »
Hello everyone, let me start out by saying that I don't have a ton of experience with amps, but I want to ask a question about altering the input impedance of a tube preamp. I have a homebrew Alembic F-2B clone that I picked up several years ago. These days I use it a lot with acoustic instruments, i.e. piezo equipped guitars, mandolins, etc. It sounds pretty good for that application but I tend to use a buffer in front of it, as the input impedance is a little low (it's 1 megOhm stock) for that application.
As far as I understand it, the input impedance is basically set by the 1 megOhm resistor on the input jack, correct? Could I safely swap out that resistor for a higher value (say 3 or 5, or even 10 megOhms) without having a detrimental effect on the rest of the circuit? That would allow me to just plug straight into the F-2B clone and get the sound I want without carrying my little buffer box.
Appreciate all of your help, thanks.
-Jim
Re: Alter Preamp Input Impedance
I would try a 2M2 or 3M3 and see if that works for you.
Add a switch to the input to go from 1m up to 10m either toggle 3 position or rotary type for more resistor options.
I have done this increase for steel guitar amps.
Post by Stevem »
If you do the impeadance switch thing the proper way to do it is to wire both resistors in series and then use a single pole single throw switch to short out the 10m resistor.
Also be sure to use a mini type toggle switch to minimize the potential issue of oscillating or picking up near by radio broadcast!
Also in above regard use minimum lead lenght on the resistors.
Tony Bones
Post by Tony Bones »
It seems to me that grid current through a 10M resistor will bias the tube very cold... until you plug in a guitar with ordinary pickups. Then the grid current will go through the pickup and restore normal bias - probably not a big deal. I don't know what will happen when you plug in an acoustic with piezo pickup. Possibly no sound because the input tube is biased into cutoff? Probably depends a lot on the individual tube.
Most people solve this problem by using an active buffer on the acoustic pickup. That can be as simple as a FET source follower.
Ten Over
Post by Ten Over »
Tony Bones wrote: Wed Sep 25, 2019 2:34 pm It seems to me that grid current through a 10M resistor will bias the tube very cold... until you plug in a guitar with ordinary pickups. Then the grid current will go through the pickup and restore normal bias - probably not a big deal. I don't know what will happen when you plug in an acoustic with piezo pickup. Possibly no sound because the input tube is biased into cutoff? Probably depends a lot on the individual tube.
I think the cathode must be grounded for grid leak bias to work. Once you put a 1.5K cathode resistor in, you will be hard pressed to detect any change in operating point even with a 10M grid leak.
A high impedance source and a cable with a lot of capacitance will roll-off the high frequencies. I don't know much about piezo pickups, but I think there is a very good chance that you will lose your highs if you run a cable directly from the pickup to the Alembic clone.
