Okay so as I mentioned the original of this board uses a Bluesmaster for the design, but I'm pretty sure it can be adapted to a #183 but I do have a few questions.  See the attached section of the tone stack.
Bluesmaster for the board:
#183 for the same section:
The part that's got me a bit confused, is that it seems like there are a few things I'm not 100% sure about.
For the middle pot, there are two things:
1. the 250kb pot in the 183 goes directly to ground
2. the BM has a switchable trim pot that is also linked to a relay.  I'm guessing I can omit this?  Which seems to me that I just either ground the pot myself and ignore that section of the board, or I can wire the ground of the pot directly to the bottom of where that trim pot goes?  Is there any potential for issues with that relay being left 'on' and doing nothign?
For the Bass, the BM goes into the top of the mid, but in the 183 it goes directly to a 10k to ground.  I'm guessing I could cut the trace on the pcb or better yet, just not run the bass grounding lug to the board and just connect it to a 10k resistor and then to a local ground on the board?
Other than that, there are quite a few component changes.
Two that had me scratching my head were:
312kb bass pot, I'm guessing this is the measured value and it's one of those cases where he scratched at the carbon trace of a different pot to get it to that value.  How much of a problem is it going to be if I just use say a 500k pot instead?  or would 250 be better?
270ka treble pot, same as above?  Just a 250k? or 500?
and the final question, the Rock/Jazz switch and PAB in the bluesmaster doesn't have the 22M resistors that the one in the 183 (and 124 I did) have, are those needed, and if so, where could I likely connect these (more for xtian and/or jazzguitargimp since they know the board).
Thanks!
~Phil
