Soldano Reverb-o-Sonic 2x10 combo is going on the work bench soon to look at the reverb problems.
Never seen such a small two 10" combo as this.
Looking for schematic. Gut shots to follow.
						Re: Soldano Reverb-o-Sonic 2x10 combo
That's an awesome looking amp.
Sent from my REVVLPLUS C3701A using Tapatalk
The speakers appear to be 16 ohms each wired in series for 32 ohms total load.
Am I seeing this right?
- Reeltarded
Yes you are.
I can’t help but wonder about the OT’s spec’s.
Just got the amp so I will let you know if the owner wired things up right which from your viewing he wired it wrong.
Complaint is for bad reverb but will definitely check the speaker wiring. Thanks.
