Hoffman chassis 6V6 project
Fender Amp Discussion
A while back I bought this Hoffman chassis from Doug when they first were introduced on his amp forum.
Decided I wanted to run 6V6 so ordered from Triodestore the 041318-48UL paper bobbin OT which was sitting on my shelf for just such a project. Primary is 6K6 and secondary 4/8/16 R for such projects as Fender Deluxe, Ampegs, and Silvertone amps.
The PT is the PT290-50 HT-6179-50 from Hoffman which is an 18w 290-0-290.
Designed and ordered the face plates (front/back) and loaded the chassis components. Fitted a blank board and still designing.
Looking for this to be a clean pedal platform small head amp.
May or may not remove rectifier tube socket and run with can type filter caps and it will be fixed bias LTP PI.
Gain, treble, middle, bass, and master volume.
didit
Re: Hoffman chassis 6V6 project
Post by didit »
If you are looking for alternate approaches, you could use a 3rd octal for 6SL7 PI and open up options. Clean goes, with reverb. Might make for a cramped box.
Best .. Ian
Everyone I know locally uses effect pedals for their sound so no reverb on this amp.
At 18 watts this should perform well despite the lower voltage this PT will put out. The PT can always be replaced with 325-0-325.
I like. This amp will be at the edge of crunchtown in a band setting. Perfect. Don't think you'll need the MV, but may be nice to have anyway. Fixed bias and SS recto are my suggestions.
68strat
Post by 68strat »
Thanks for posting. Darn cool lil amp project
ChopSauce
A few more "naĩve" questions
Post by ChopSauce »
The chassis looks rather small. This will make for a compact amp 8)
EDIT :Oops! By lookiing - too quickly - at the miniatures, I mistaken the front of the chassis with the back, and the octal sockets for noval ones...
:roll:
... I was too enthousiastic, maybe. I was thinking about something else at the same time, for sure :wink:
Thanks for sharing, anyway!
Using 2 preamp tubes into pair of 6V6's JJ's, solid state rectifier (removed the last octal tube socket) and installed JJ 40/20/20/20 can cap.
Recto board will go on end of chassis near PT.
Made the component board and loaded that.
I'm going to wait on faceplates to continue with wiring.
The PT 290-0-290 I think was originally chose by Hoffman to run a pair of EL84's using adapter plate for his Stout circuit but I wanted 6V6's.
Might not be enough plate voltage for a really clean output should have around 325-0-325 might have to change that out.
68strat
Post by 68strat »
Mark, thank you for all your threads and post. Super cool of you
Glad you enjoy I will be posting more photos as the project matures.
Taking 12 family members to Minnesota zoo, Valley Fair and Mall of America soon so not much will get done between now and end of June.
dcribbs1412
Post by dcribbs1412 »
Looks like a fun amp Mark
I have used that OT in a few 6V6 builds...a little pricey but its nice
Sounds like some fun summer activities
Have fun with the family
D
Got some time on this project.
JazzGuitarGimp
Post by JazzGuitarGimp »
Looks like the first octal socket mysteriously trandformed itself into a multi-section cap can..... 😁
Lou,
As I am working on this amp I keep changing things such as replace the tube recto with diodes and add 40/20/20/20 JJ can cap.
I might even try cathode bias and later, if needed, change over to fixed bias.
Used whatever caps and resistors I had in stock.
"FVA"! Nice faceplates.
xtian wrote: Wed Jul 12, 2017 2:55 pm "FVA"! Nice faceplates.
Thanks, anodized aluminum from Front Panel Express which now have printing option instead of milling the panels.
