Trainwreck Express Head Cabinet step by step
JPGraphX
Post by JPGraphX »
Hi,
I've almost finished my build. I need to make a head cab.
I searched forum but did not find any "step by step" tutorial on how to make a wood cabinet. Is there any links you can propose me ?
Thanks a lot,
JP
JPGraphX
RJ Guitars
Re: Trainwreck Express Head Cabinet step by step
Post by RJ Guitars »
Hi JP,
We would all be delighted to see the build photos and the learn some of the story on your Express... do you have a thread running on that?
The Wreck cloners of yesteryear put together some good documentation on how to build an ~authentic Wreck cabinet and posted it for us. I'll repost it for you... please send us a finished photo if you don't mind.
thanks,
rj
http://www.rjguitars.net
JPGraphX
Post by JPGraphX »
RJ, yes I have thread. I'll post picture when it's over! By the way, I built it with your kit ! ;)
JPGraphX
Scott_F
Post by Scott_F »
Looking forward to it.
Richie
Post by Richie »
One problem with the cab layout is the opening for the chassis. It shows 2" you have to have more than that for the wiggle room of a bottom plate etc.
RockinRocket
Post by RockinRocket »
Were the cabinet plans made from a actual Wreck? Or just a guess?
Post by Mark »
I worked with Matt Taylor on this and it was all done from photo's blown up to life size.
The drawing worked for a lot of people but it may not be a one size fits all.
Measure your chassis and see it the cab measurements will work for you.
Yours Sincerely
Mark Abbott
Richie
Post by Richie »
I think it depends on what you use as a bottom plate, its thickness,and if you use cork or felt on the bottom of that.
If no cork and a thin bottom plate, the opening could be a hair shy of 2 1/4 maybe more like 2 1/8th or hit in between 2- 1/8th and 2-1/4.
As mentioned, depends on what you will be using as the bottom plate etc..
ampmike
Head cab
Post by ampmike »
Ill help you out,give me a call anytime buddy.570 977 0653 Mikey
http://faithamps.weebly.com/
JPGraphX
Post by JPGraphX »
Work in progress! My wood is Jatoba.
Thanks all!
JP
ampmike
Nice
Post by ampmike »
Lookin real nice buddy!!!!!Love that wood :D Mikey
Ron Worley
Post by Ron Worley »
These were done using measurements off an actual Wreck cabinet supplied by an owner. As Ritchie mentioned, there might need to be a slightly larger opening in the front for the chassis, but the measurements I drew up reflect what I was given.
Ron
JPGraphX
Head cab
Post by JPGraphX »
Hey guys!
Here is first layer(of 3) of finishing oil. I used Prato-Verde Secondo, from Québec, Canada.
How do you mount the aluminum chassis with the wood cab?
Thanks,
JP
Ron Worley
1/4 inch thread machine screws, roughly 1.5 inches long, but I forget the length exactly.
Ron
