BM build
dcribbs1412
BM build
Post by dcribbs1412 »
Finally fired up a 50 watt BluesMaster build I
started a few months ago.
Using some boards I etched and some PCB's I had from a member
Still tweaking the OD tone stack pots, but pretty decent tones out of the gate
On board loop is nice and quiet. OD FET PAB on relays, Bright, Mid boost on front switches. Hard wired Rock mode.
This circuit along with a 335 is really a blast.
Going to clean up the wiring, let it burn in and roll tubes.
D
Smokebreak
Re: BM build
Post by Smokebreak »
That really looks great!
dreric
Re: BM build
Post by dreric »
Nice, I have a set of those boards, inspiring!
Eric
1949 Zenith, Zenith Toggle Recoil, Zenith 55 & 440
Aaron
Re: BM build
Post by Aaron »
Nice job. Wiring looks great to me.
dcribbs1412
Re: BM build
Thanks guys
Really like this circuit, bonding with the 335
Will post pic of head cab.
Voltage might be a little high at PI, info I've seen is 240-250V thinking about adjusting voltage some if rolling tubes don't bring it down
although it sounds good
472 on plates
188-190 V1
209-211 V2
306-307 v3
Biased at 33mA
D
