Rock/Jazz switch: how does the amp react with or without it
Currently I have an ODS style amp that is lacking the rock/jazz switch. I know how to add one in, I was just curious if anyone could elaborate on the tonal shift that will occur once installed. Thanks!
fenderbender
Re: Rock/Jazz switch: how does the amp react with or without it
MY take on it is that when in the "JAZZ" mode, the output is lowered and it sounds a little more "HI-FI-ish", if that makes sense. With other words the tonal response seems a little flatter across the bandwidth of the amp. In my personal opinion, the "Rock" mode suits my taste much better, at least with the Skyline EQ. I haven't tried it with the "Classic" EQ. Your mind may vary. I've built them with and without the Rock / Jazz switch and I felt that that switch added complexity to the build, where the payoff of was minimal. Again, this is just my 2 pennies.
Best regards,
Tommy J.
Best regards,
Tommy J.
It sounded so sweet... And then it caught fire!
