Dremel tool vs stainless steel hardware? Sure, you betcha':
https://youtu.be/k0vCnUqa-50
									"Will it cut?"
"Will it cut?"
						Re: "Will it cut?"
Why on earth would you want to do that? The whole idea of using a screw is that it can be unscrewed! If you want it permanent, use a rivet. Neater, faster, cleaner.
Yeah, a Dremel works just fine. The cut off wheel will probably do no more than 4 screws, maybe less.
Re: "Will it cut?"
Ha! True. But in this case the screws had to be shorter because my bad design would not allow 6L6s to seat.
						Re: "Will it cut?"
Opps! Sorry, I didn't realize you were showing your own work  BTDT. I don't remember what I did. I think maybe I cut the screws short and put the nut on the outside. We all have to improvise from time to time.
