5f1 bad distortion
Fender Amp Discussion
JoshBernstein
5f1 bad distortion
Post by JoshBernstein »
Hi, I recently built a 5f1 clone and im having some weird issues with it. It worked fine and sounded good for the first month or so, until i decided to start tinkering with the nfb resistor. At once point, i decided to disconnect the 220k resistor that goes from the coupling cap to ground to get a better angle, and forgot to reconnect it. I then played through the amp for approximately a minute before the volune was suddenly halved and there was a burning smell. The 6v6 socket had been arcing from pin 2 to 3, and the tube was toast. When i realized my mistake, i put a new socket and tube in and reconnected the 220k resistor, but i am now getting some really bad, almost static-y distortion at high volumes. At lower volumes there is no distortion; it starts between 4 and 5 on the dial. Any ideas on what it could be? I know people say its usually the last thing to go, but could it be the ot due to the direct arcing from pin 2 to 3?
Thanks!
Not really
Kk
Post by Stevem »
Measure you idle current on one of the outputs and then play thru the amp if you see the current go up a good amount and the volume is low and ratty then your OT is shorted on the primary and is toast!
Lll
Post by Stevem »
Also be sure that any traces of the arcing ( carbon track) from those two pins is gone!
I use a sharp metal scribe to get back down to bare plastic if the socket is not ciramic .
JoshBernstein
Re: 5f1 bad distortion
Will measure the current when i get home, but the arcing is totally gone, as replaced the socket.
Not really
My guess is the OT is fried. If the output tube's grid is floating, the primary current will go sky-high and overheat the transformer.
pdf64
Post by pdf64 »
Fitting a fuse to the B+ would be a beneficial mod.
