What can I do with this? I have been totally drooling over a Trainwreck or even better .. a Komet 60. I think all that I can use is the trannies and the chassis.
The schematic I found is for the B-2000 .. same amp but with an extra input channel.
My schematic reading skills are not the best. Is there a way to figure out the outputs of the power tranny based on the schematic? If not, how can I use a VOM to figure it out? I have not tried to turn the amp on, found a big cap not attached. I will solder that up tonight and fire it up. It came with tubes, but most of the lettering has rubbed off.
It looks like the output tranny has an extra tap that is not used. From the factory, only the 4 ohm tap is wired to the speaker outputs. I read on another forum that the unused tap is 8 ohm. Any way that I can test what the primary tap on the OT is? For quad 6L6's, what should it be?
So my questions are .. How do I find out the values of these trannys and are they suitable for use in a Trainwreck?
Once I figure that out ... then comes the millions of questions about building one (my first build ... can you tell?)
 BTW, love this board !
