Gibson EH 150
aabbs20
Gibson EH 150
Post by aabbs20 »
Hi all!
I'm a newcomer to the forum and a hobbyist builder. I've built a number of tweed circuits and I'm thinking of a Gibson EH 150 next. It has been tough to find info and other builds. Any one have experience with this circuit?
Thanks!
Re: Gibson EH 150
Post by Stevem »
I assume you are thinking of building one of the latter one that do not use a transformer for a phase splitter as they are gonna be hard to come by!
aabbs20
Re: Gibson EH 150
Post by aabbs20 »
Thanks! I did a bit of fruitless searching but I must have done something wrong because those results didn't turn up.
Re: Gibson EH 150
No problem.
Teleguy61
Re: Gibson EH 150
Post by Teleguy61 »
Search function takes a bit of learning.
Note that Mark used EH+150 in his search.
Use of the + sign is important.
aabbs20
Transformers?
Post by aabbs20 »
What transformers did you guys use in your builds? David you used an all TP25, but are there better options? Do you guys have a recommendation for a low voltage secondary PT? Is it better to get a higher secondary and drop it with a Zener?
Thanks.
Colossal
Re: Transformers?
Post by Colossal »
aabbs20 wrote:What transformers did you guys use in your builds? David you used an all TP25, but are there better options? Do you guys have a recommendation for a low voltage secondary PT? Is it better to get a higher secondary and drop it with a Zener?
Thanks.
The target plate voltage is 275-290VDC, Class A cathode bias, push-pull. About 20VDC on the cathodes. The original amps (Types II, III, and IV) used a Thordarson T-40069 PT which was 408-0-408. Yes, that's right. There was a field coil speaker inline with the B+ string which provided a voltage drop (use a choke to sub for the field coil) but also, and importantly, there was a 20k 25W resistor TO GROUND in the B+ string, parallel to the reservoir cap.
aabbs20
Re: Gibson EH 150
Post by aabbs20 »
So I should look for a PT with something around 400 on the secondary?
Re: Gibson EH 150
I used:
Hammond 274BX 750vct 175mA
Hammond 1645 30w 128mA 5k primary to 4/8/16 secondary
Hammond 158M choke 10H 100mA
Colossal
Re: Gibson EH 150
Post by Colossal »
aabbs20 wrote:So I should look for a PT with something around 400 on the secondary?
It depends if you are trying to make a historically accurate clone and/or whether you want solid state or tube rectification. The originals were tube rectified (5U4G). If you will not be using a field coil, then I would use a 1k 25W resistor in the first Pi filter.
aabbs20
Re: Gibson EH 150
Post by aabbs20 »
M Fowler:
Thanks a ton! What did your B+ end up at? Your build looks great too, I'll be referencing it a bunch. Did you punch your own chassis?
Colossal:
I definitely want to use a tube rectifier and be somewhat historically accurate. I won't be using a field coil speaker but would love to have the plate voltage nice and low. Thanks for the tip on the 1K 25W resistor as well.
Re: Gibson EH 150
aabbs20
You should see Colossal's build it's really impressive.
Yes I punched my own chassis a Watt's 17.5x8x2.5 I believe and is in my opinion too large. Long wire runs everywhere.
119AC wall
B1 473
B2 447
B3 390
B4 203
Plates 447 6L6
Screens 439
David Root
Re: Gibson EH 150
Post by David Root »
Dave, I originally built mine to the 400V version in Tino Zottola's book. I used the Allen TP25 because it was about the right voltage and it fit the cut out/mtg centers in the Mojo knockoff BF Princeton Reverb chassis I used. Ended up with ~375V plate using a Hammond 158Q choke (5H, 150mA), CL feed.
When I decided to go to the lower voltage, as originals ran about 270V just like the 6L6 data sheets of the day, I just changed the CL feed to LC choke feed by reversing the positions of the choke and the reservoir cap, and also changed the rectifier from a 5R4 to a 5AR4, to get back up to 280V plate. An old Mullard, not a Sovtek, which won't get down to 280V in that scenario.
BTW it took me a while to figure out what the original plate voltage was, I finally found it, I think it was on an EH185 schematic IIRC, which by that time (1941-2) was the same as the EH150.
Also, I heard that the 6N7 PI could be noisy/hummy and wondered if anyone had tried a 6SN7 instead, and if so did that kill the residual hum? I used the 6N7 and even choke fed it's not quite as quiet as I would like, although I wouldn't be surprised if it's quieter than an original EH150.
Colossal
Re: Gibson EH 150
Post by Colossal »
aabbs20 wrote:Colossal:
I'll have to look at my notes on the field cool resistance but IIRC, 850R - 1k should be about right. If you use a 390-400VAC secondary and a 5U4G, be sure to use that 20k 25W bleeder resistor to ground, parallel to the first Pi filter.
