Hi , what Hiwatt power amp and PI can I use with pre-amp Alembic f2b ?
any suggestions are appreciated
S.
50w power amp for Alembic f2b
Re: 50w power amp for Alembic f2b
are you trying to recreate some David Gilmour vibe? If so, I think a DR50 would do fine. Bring B+ down some for modern EL-34 or JJ 6V6s.sergio wrote:Hi , what Hiwatt power amp and PI can I use with pre-amp Alembic f2b ?
S.
I want build a stand alone power amp to use with an Alembic f2b Rack.
S.
S.
dcribbs1412
http://hiwatt.org/tech2.html
lots of great info here that may help you
Mr. Huss is a member here I believe
also some info at AX84 may help
http://www.ax84.com/corepoweramps.html
D
D
