My Latest #102 Build
- glasman
https://www.facebook.com/media/set/?set ... 4747b2fc22
A few photos of my latest #102 build (Overdrive Deluxe amp).
Hopefully the link works.
Gary
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
- glasman
Re: My Latest #102 Build
Does the link work?  Just curious if Facebook allows the external linkage,  works for me...
www.glaswerks.com
www.glaswerks.com
Yes, no problem for me. Looking good!
						- glasman
Thanks Martin!!martin manning wrote:Yes, no problem for me. Looking good!
www.glaswerks.com
www.glaswerks.com
Works here as well.
Looking great.
Will steal few tricks - hope you don't mind - that bug style mounted Orange drop on V1 in particular ...
Niki
						Looking great.
Niki
- glasman
Thats ok I stole it from Dumble lol.Synchu wrote:Works here as well.
Looking great.
Will steal few tricks - hope you don't mind - that bug style mounted Orange drop on V1 in particular ...![]()
Niki
www.glaswerks.com
www.glaswerks.com
- glasman
The cap is held with hot glue. I cut a small piece of glue stick and then using a hot air gun, I preheat the chassis to the point where the glue starts to melt when I touch the glue to the metal. Once I get to this point I continue to heat the glue and metal with the hot air gun until fully molten and then press the cap into the glue.Synchu wrote:Works here as well.
Looking great.
Niki
I have found that unless the metal is preheated, the glue will not stick to the aluminum chassis.
Gary
www.glaswerks.com
www.glaswerks.com
Dumble would have used silicone adhesive, though, no?
						- Luthierwnc
Very nice!  I've got a 102 variant on the bench now.  sh
						- glasman
No sure to be honest, I have tried silicon based adhesives and I have not found any that really stick that well to aluminum. Them seem to like to release over time.martin manning wrote:Dumble would have used silicone adhesive, though, no?
Two part epoxy actually might be a potential solution as well.
But at this point the preheat process has worked well for me.
www.glaswerks.com
www.glaswerks.com
Very sweet indeed!  I like that mounting trick as well.  epoxy or JB weld may in fact be a solution - I'm not particularly smart on what works with what or what melts what, so thanks for the shared experience on silicone too -
				dcribbs1412
Nice looking build Gary
Any chance you will be at the Tempe Guitar Fest?
Darin
Darin
- glasman
I will probably go and wander around. No booth. Been a couple of years since I attended.dcribbs1412 wrote:Nice looking build Gary
Darin
You can recognize me by the Glaswerks Logo on the back of my jacket lol.
Gary
BTW, you are always call here. 480 898-1058
www.glaswerks.com
www.glaswerks.com
Hey Gary,
Great tip on the mounting.
I learned that silicon based ones do not work the hard way. Had an F&T RC filter mounted that way in couple of hi-fi monoblocks I did. One stays and the other didn't.
But certainly doesn't work quite well, or at least the one I am using. I didn't use any since then, but I am sure back to hot glue.
Thanks,
Niki
Thanks,
Niki
