dehughes wrote:Wow.  Thanks man!  Maybe I'll try this then...if it isn't to complicated...  So, when you say leave the negative bias voltage hooked up to the trem....what exactly does that look like?  I'm still not getting it...
My mental picture is that I leave the 1k5 grid resistors in place, and then connect them to a set of 220k resistors that go to ground on one end and on the other end connect to the PI caps.  Attatch a cathode resistor and cap to pin 8 on the 6L6s and I'm done.
Do I then unsolder the two leads that go to the hum balance pot?  I'm a bit confused....I'm not used to working with tremolo circuits...
Thanks!
the hum balance pot has nothing to do with the trem-----it's just a ground reference for the filament winding since it doesn't have a ct---it functions just like the 2 100ohm resistor setup you see in many amps.
the other "balance" pot is the bias balance pot -----it's not a true bias adjustment like in blackface amps--which is why people change it to a true bias adjustment, like the blackface circuit.   just make the top part of your pi circuit look just like you said:   2 220k load resistors to each coupling cap, their centers to ground (remove any of the fixed bias supply that is attached in that part of the board).   don't worry about the trem---it's got nothing to do with any of this.  you need a schematic so you can see what's going on if you can't tell from the board. btw, find the 2.2m resistor in the trem circuit--that's where the neg. voltage supply ties in to it.
i'd personally do what these guys have alluded to---change the whole thing to the blackface circuit values---it really doesn't take much.    just go to schematic heaven and get any ab763 or aa763 of any of the fender models from deluxe on up thru twins---it's all the same.
http://www.schematicheaven.com/fenderam ... tr_rev.pdf
chances are this is the amp circuit you currently have from what details you've described.    the caps across the diodes are not a mod---this is stock fender from this era and you see others do it as well.   it's to help get rid of the diode switching noise if indeed it was a problem.    rh
