For an average mans rig, what loadbox would you use to bring down the signal from the output of your amp to the input of an effect processor and then to a power amp?
I know that many of the Trainwreck users that don't have an FX Loop have use similar solutions to use effects after your Trainwreck.
						transparent loadbox for amp->loadbox->effects->powe
- El Chiguete
- El Chiguete
Re: transparent loadbox for amp->loadbox->effects->powe
Rat Valve Amp Speaker Dummy Load Box http://ratvalveamps.com/dummy-load
Anyone used this? does it suck tone? I'm looking for a dummy load with a line out without speaker cab simulation.
There have been good reports on the Bad Cat Unleash; it does what you want:
http://www.badcatamps.com/unleash.html
Operating Manual:
http://www.badcatamps.com/public_img/image_167_559.pdf
Operating Manual:
- El Chiguete
In another thread I got reminded of the ADA GCS-2 and GCS-3 http://www.adaamps.com/Products/ada-GCS/GCS.htm (basicly the difference is that the GCS-3 can handle speaker level signal but the balance output is only in line level and in the GCS-2 it is selectable between line level and instrument level).
