Bassman Bias Circuit Questions
Fender Amp Discussion
tbbeck
Post by tbbeck »
In a recent 5f6a build Ive ran into a problem with my bias circuit. A 50v tap from the power transformer runs to the cathode end of a 1n4007 diode and then to a 10uf 100v cap, followed by a 15k resistor, another 22uf 50v cap, and finally a 50k bias pot. Unfortunately when I power it up the first 10uf cap keeps blowing. I've double checked my wiring and I can't seem to figure it out. Any ideas as to what might be happening? Attached is a schematic of the problem area.
statorvane
Re: Bassman Bias Circuit Questions
Post by statorvane »
Can you post a photo of your amplifier's bias circuit wiring?
ToneMerc
Post by ToneMerc »
Sounds like that first cap is not orientated correctly, is the positive end grounded?
TM
CHIP
Post by CHIP »
ToneMerc wrote:Sounds like that first cap is not orientated correctly, is the positive end grounded?
TM
That's what it sounds like to me. I did it once, the e-cap went off like one of those black cat firecrackers that we used to play with as teenagers.
Post by Stevem »
Blown off firecrackers smell way better than popped elec caps! LOL.
billyz
Post by billyz »
Your schematic is wrong. Positive to ground not cathode. Your making negative voltage not positive. Reverse both caps!
Looks OK to me- although it isn't marked, the straight plate in the symbol is the positive end.
billyz
Post by billyz »
Ok, my bad . Alzheimer's . Looking at the cap thinking diode.
vibratoking
Post by vibratoking »
The cap orientation in the schematic looks correct. Did you wire it according to the schematic? The schematic shows the postive end of the cap to ground. The fact that it is blowing up indicates that you are putting it in backwards.
roberto
Post by roberto »
I bet on reverse polarity.
printer2
Post by printer2 »
Popped the first cap myself on my current build. So used to seeing the negative grounded I automatically hooked it up that way. Won't be doing that mistake again.
Teleguy61
Post by Teleguy61 »
2 for reverse.
