Broken speaker terminal plate
AcornHouse
Post by AcornHouse »
Ok, while soldering up a speaker cab, the jack plate slipped and broke off the terminal plate off the speaker. Luckily, I hadn't soldering the wire on yet, it was just clipped on, so the lead wires to the terminal plate didn't get ripped off.
Silly slip, I know. But how do I get the terminal plate, which appears to be cardboard-like (it's a Weber speaker), reattached? It broke off right at the basket.
Thanks in advance.
Re: Broken speaker terminal plate
It's probably riveted on, right? You can drill out the rivet and reattach with nut and bolt.
AcornHouse
The rivots are on the bit that stayed attached to the basket. The rest snapped cleanly off.
AcornHouse
Maybe CA glue the plate at the break, with some reinforcing material glued across the joint on both sides?
drill the rivet. make sure to catch all the metal shavings . and replace it with a larger nut ,bolt and washer.Like Christian said
If there's not enough meat left to bolt down then you probably ned new terminal piece
There was a thread here just recently about where to find replacements plates for the spade terminals.
I'm sure Weber would send you a new terminal.Or atleast they would have I haven't bought anything from them in a long time
AcornHouse
Thanks guys!
cbass (seabass!) and I are similarly tilted.
xtian wrote:cbass (seabass!) and I are similarly tilted.
We're pretty clever fellows
We both have pictures of ourselves on our avatar too.
We ain't bad lookin guys either
